Go to Post And now you know why we have a " No Karthik singing zone " north of the border. - Steve W [more]
Unread 23-02-2013, 20:22
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Balancing a Pneumatic wheel
We've got 2 6" Andymark pneumatic wheels on our shooter, and we were having some major issues with vibration due to the air spigot throwing off the weight distribution. We removed the innertubes entirely and filled them with bubble wrap which helped some, but it still vibrates badly because the tire doesn't seat particularly well without inflation. For teams that are using pneumatic shooter wheels, what did you do to balance them?
Also, did anyone find a different type of wheel to be superior?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 23-02-2013, 20:56
SailorDad's Avatar
SailorDad SailorDad is offline
AKA: Rob Peace
FRC #1123 (AIM)
SailorDad is an unknown quantity at this point
Re: Balancing a Pneumatic wheel
We are using a single 8" pneumatic wheel and the team taped a few small nuts/bolts into the spoke opposite of the filler tube. Works fine.
We were running the tire without an innertube but discovered it flattened out too much and it was difficult to get a good grip on the disk.
Burke, VA
Unread 23-02-2013, 22:07
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
We used 1/4 oz tire weights from Harbor Freight - they're adhesive backed and worked like a charm!
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 23-02-2013, 23:20
Brandon_L Brandon_L is offline
doot doot
AKA: Brandon Liatys
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Two long bolts on the holes opposite of the air nozzle, with washers stacked on them. Our sweet spot was 9 washers on each bolt, give or take a few for others depending on bolts/nuts and such.
Am I the only one that watches lunch with Andy?
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
Back for 2017!
Unread 23-02-2013, 23:29
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron)
Step 1: Take the inner-tube out.
Step 2: Fill the tire with pool noodle which has been cut in half.
Step 3: Thank your friendly M'Aiken Magic mentor from South Carolina.
Works like a champ, promise.
John Fogarty
Unread 23-02-2013, 23:46
Data Nerd
FRC #0079
Remind me to wear my kevlar vest to any event you're at.
Seriously, don't forget to take into account that these wheels are running at speeds they were NOT designed for. Make sure anything you attach to them can handle the speeds.
Unread 24-02-2013, 00:05
Andrew Lawrence
Do what we did: Just take the tubing out! Literally. Just the hub and the rubber tire. No inner tube. It works beautifully.
Unread 24-02-2013, 00:59
ksafin's Avatar
AKA: Kirill Safin
Well we've probably run the shooter wheels, in total, for over 2 hours of run-time and nothing has ever gone wrong (this is actually an insane amount of time considering robots are typically not run for very long times).
When you couple the strong adhesive and with the centripetal force of the wheel, there's no way these puppies will fly off.
Unread 24-02-2013, 10:39
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
I know team 3130 removed the whole inner tube and replaced it with pool noodle and had great success with it.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 24-02-2013, 11:29
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
I think if the weights will work on sport bikes that they will be fine on a robot wheel a 2006 yzf r6 has a top engine rpm of around 21,000RPM. The sixth gear reduction ratio is 1.074. Dividing 21,000RPM/1.074 will produce the RPM of the rear wheel. This comes out to be 19,553RPM. I don't think the shooter wheel is hitting that speed lol Now i realize you may do the math and realize nobody ever drives that fast but when the bike is doing 250MPH, people do drive that fast on the track, the rear wheel is spinning at abut 3,703RPM which is faster then any shooter wheel is spinning. So Andrew you are just fine using wheel weights
Unread 24-02-2013, 11:52
Data Nerd
FRC #0079
3703 < 5000 So I'm not seeing your point. I know one of my wheels is geared close to 7500 rpm. Now, I'm aware I'm not hitting that speed but I'd be willing to bet you that it's well above 3700rpm. And frankly, I don't care if it "should" be safe. I care that it is. I care that teams took some time to put in safe guards to prevent shrapnel hitting people because I'm selfish and I enjoy the use of all of my limbs.
Unread 24-02-2013, 11:55
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
That's well over 1200 miles per hour. I don't think the wheel itself would survive, much less stick-on weights.
Based on reports I've seen here, some frisbee shooters are spinning their wheels at 6000 RPM or higher. 5000 RPM seems common. Whether or not you use wheel weights, if you're running a wheel at several thousand RPM, you'd better have an effective containment system to protect the outside world in case something spontaneously disassembles itself.
Unread 24-02-2013, 14:59
I believe those are the smaller wheels, not the pneumatic. If someone is spinning that pneumatic wheel over 4,000 RPM then the are lucky they still have a wheel.
Unread 24-02-2013, 15:36
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Something to consider is that the way most teams practice is not indicative of an FRC match. Their is significantly more vibration, impact, and otherwise dynamic loading that the robot will see during a match compared to the loads it sees when you drive around picking up frisbees without the full contact of a typical match. Any field reset volunteer could tell you about the buckets of stuff they have to pick up off the field.
I think many people are running tires at 1:1 off a CIM and just assume they are getting close to a no-load free speed. If they were to put a tachometer on it I bet they would find their true rotation rate is significantly slower.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 24-02-2013, 15:56
Software Architect
The TechnoKats robot this year uses the pneumatic tires from AndyMark. I think the operator typically calls for 3000 RPM, but it can go to 5000 on command without trouble.
The final output wheel on the TechnoKats shooter has a Spinbox in "overdrive" configuration on a MiniCIM motor. It definitely exceeds 5600 RPM when run full power (the cRIO stops getting a good signal from the encoders above that rate).
The wheels are well balanced (though there is still enough vibration to matter) and there is a shield in place to keep debris from flying out if something comes apart at speed.
