Go to Post It'd be nice if, one day, people just concentrated on how to inspire your own team and your own community. Let others decide on how to inspire theirs. - George1902 [more]
Unread 23-02-2013, 22:39
Joey Milia's Avatar
FRC #0192 (GRT)
pic: Team 192's 2013 Gearbox
Unread 23-02-2013, 22:40
Andrew Lawrence
Re: pic: Team 192's 2013 Gearbox
I was waiting to see this. Always love 192's gearboxes. Can't wait to see this things in-person at SVR.
Just curious - why the tiny output shaft? That looks like it could barely hold a sprocket.
Unread 23-02-2013, 22:47
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Wow. That's absolutely beautiful. I assume you're using bevel gears?
Unread 23-02-2013, 22:50
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
I do love that black and red...looks real sharp
If I had to guess, I'd say they're doing something similar to 971's setup last year and putting the last stage of the gearbox on the output shaft and a dead axle wheel.
Unread 23-02-2013, 22:59
Andrew Lawrence
Ah, that makes a lot more sense.
Unread 23-02-2013, 23:07
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Is it a worm drive inside or plain bevel gears?
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 23-02-2013, 23:12
Joey Milia's Avatar
FRC #0192 (GRT)
One of the goals of the gearbox was to reduce it's footprint, and that includes the space it takes to install and remove it. To that extent the output shaft is split into two parts, half in the gearbox, other half in the sprocket and wheel. This allows the gearbox to be removed after pulling it only 5/8 of in inch into the robot, instead of the 2-3 inches that would be required otherwise.
More specs,
two speed shifting 17fps and 6fps
Cim to cluster shaft is 3mm GT2 Belt
and yes, there is a bevel gear in there.
Unread 24-02-2013, 01:52
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Just wondering, do you have any idea about the gearbox's efficiency? Just looking at all those shafts makes me wonder if you're loosing some power through all those reductions.
But seriously, that looks like a marvel of smart design and good machining. So many bends and bearing holes, all lining up perfectly...
-Plutarch
Unread 25-02-2013, 21:42
Joey Milia's Avatar
FRC #0192 (GRT)
I don't have any hard data on efficiency but it's just a three stage shifting gearbox, one of which is belts from the cims. All stages are in the 98%-99% range, add on the sealed bearings and I would expect an efficiency in the low 90s.
Unread 25-02-2013, 22:43
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
How are you getting such high efficiency per stage?
Mentor 2415
Unread 25-02-2013, 22:56
Joey Milia's Avatar
FRC #0192 (GRT)
The main reductions are spur and bevel gears, which, when alined properly with accurate tooth profiles and proper lubrication are extremely efficient. Once again I have no measured data to support these estimates, they are based on subjective observations and engineering manuals (mostly engineering manuals).
