Go to Post "If you can't hurdle, you can't win." "Remember to practice your obnoxious amateurism." . - dlavery [more]
Unread 04-03-2013, 11:00
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
Re: pic: Team 2590's 2013 Robot
Originally Posted by lynca View Post
Congrats on the 17-1 record and regional win !
Thanks! We rolled a lot of what we learned last year into this robot.
1. What coupling mechanism do you have in between your shooter motor and shooter wheel?
The motor couplings are beam couplers from Ruland (http://www.ruland.com/ps_couplings_flexible.asp). We used them on our shooter last year as well (cim-sim's in that case).
2. What type of spotlight are you using?
LED Ring lights from superbrightleds.com, same vendor as almost everyone used last year. We're using a 60mm and an 80mm green ring. They're epoxied onto the plastic camera housing. One is plenty, but we like having a bit of redundancy/overkill in that instance. We caught a stray frisbee on Saturday that killed 3 of the LED's. We might try putting a clear plastic shield over the LED's to prevent that in the future. Last year we left it exposed with no issues.
3. Did you use the spotlight in your autonomous and in teleoperation?
Yes, we're using it in both modes. We use the data to calculate distance and angle from target. That data feeds into the shooter wheel speed control and a "turn to target" function. The turn to target still needs a little tuning for autonomous.
