Go to Post ....a red-light-of-death. - Kevin Watson [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
  #166   Spotlight this post!
Unread 17-03-2012, 23:40
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
Re: paper: New Scouting Database from Team 2834
Hey Ed!
First off, thank you SO MUCH for doing this!
Secondly, would it be at all possible to have the file available as a ".xls"? My Mac doesn't seem to like the .xlsx
Thanks! If it works better for you to email it to me, shoot me a DM!
Thanks!
  #167   Spotlight this post!
Unread 18-03-2012, 00:34
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Originally Posted by Mike Starke View Post
Hey Ed!
Thanks!
Please PM me your email address. You have no contact info on CD.
Please don't call me Mr. Ed, I am not a talking horse.
  #168   Spotlight this post!
Unread 19-03-2012, 08:19
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
This is an amazing spreadsheet. As someone who used to write Lotus 1-2-3 macros back in the day, I am in awe.
I was able to run the macros to update the week 3 regionals successfully. How do I get that data merged into the OPR and WM tabs?
Thanks...
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
  #169   Spotlight this post!
Unread 19-03-2012, 10:16
Ed Law's Avatar
Thanks...
I am glad it worked out for you. Every week after the events are over, I update the OPR numbers, check to make sure all results FIRST posted are correct, and then I transfer that week's data to the OPR and WM tabs. I guess I am performing the Quality Control function and make sure there is only one set of data in the CD community instead of everybody running them and potentially have slightly different numbers.
Week 3 data were already posted yesterday. There is a separate post to discuss each week's data. See http://www.chiefdelphi.com/forums/sh...hreadid=104743
  #170   Spotlight this post!
Unread 19-03-2012, 13:12
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Dr Ed Law,
Thanks for revising the database to add points for teams that elected to gather coopertition points for their alliance. At the Michigan Waterford District tournament we found ourselves often in a position that we were the most consistent bridge climbing team and other opposing alliance often met with us to discuss going together on the white bridge to gain this valuable seeding points. We could have climbed the alliance bridge for 10 points but elected to go the other route. Should the coopertition points really be 10 points instead of the 5 shown in your database? We still climbed a bridge and balanced?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
  #171   Spotlight this post!
Unread 19-03-2012, 13:29
Ed Law's Avatar
Originally Posted by marccenter View Post
Dr Ed Law,
We are giving 5 bridge points for every 1 coop point. However when you balance on the coop bridge in each match, you get 2 coop points which means you are getting 10 bridge points. If you had gone to the alliance bridge by yourselves or balance with a partner, it is also 10 points extra, so it is the same. If you feel that you want to look at it differently by sorting using more than 5 bridge points for every 1 coop point, you can change the number in cell AF1 to whatever you like.
  #172   Spotlight this post!
Unread 19-03-2012, 14:02
Ed Law's Avatar
Hey Ed!
Thanks!
Mike, it is your lucky day. Excel finally cooperated and let me write it out in .xls format.
Ether, now you can look at the data using Excel 2003.
  #173   Spotlight this post!
Unread 19-03-2012, 14:07
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Thanks Ed !
  #174   Spotlight this post!
Unread 22-04-2012, 23:27
Ed Law's Avatar
The database has been updated with Divisions information and links were set up for use at Championship to easily update the OPR etc. if you have access to the internet.
Good luck to all at the Championship. Our team is in Newton division. Stop by to say hi. I would love to hear from you and how you use this database for your team.
  #175   Spotlight this post!
Unread 23-04-2012, 12:35
Jacob Plicque Jacob Plicque is offline
FRC #0086 (Team Resistance)
Jacob Plicque is an unknown quantity at this point
Cool Re: paper: New Scouting Database from Team 2834
Ed,
Thanks for the update. Your efforts make it a lot easier for Team 86 and surely others to find the diamond in the rough.
In my previous email, the playoffs were correctly predicted by the eliminations about 70% of the time. Have you considered calculating the playoff rounds with the elims to raise the accuracy of the predictor?
See you in St Louis.
Jacob
Mentor Team Resistance
Newton Division
  #176   Spotlight this post!
Unread 24-04-2012, 00:01
Ed Law's Avatar
Originally Posted by Jacob Plicque View Post
Ed,
Jacob
Newton Division
We are in Newton Division too. I will look forward to seeing you. Perhaps we can share our scouting data.
  #177   Spotlight this post!
Unread 27-04-2012, 09:38
Ed Law's Avatar
Championship data version 2 is out with Thursday's results. I also fixed some of the link problems that I can find.
  #178   Spotlight this post!
Unread 27-04-2012, 21:24
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Hi Ed,
We seem to be having a problem with updating Thursday's database for Friday's results. Crtl+Shift+P updates the ranking and official FIRST data, but the OPR data doesn't appear to change. Are we missing something? Thanks
  #179   Spotlight this post!
Unread 28-04-2012, 00:59
Ed Law's Avatar
Championship data Version 3 including Thursday and Friday results are uploaded. I fixed one problem with the OPR data calculation. However there is something very strange going on with the links. It keeps changing the link to KC, NH, TN and STX. If the Ctrl Shift P does not work, you will need to manually copy and paste into the spreadsheet.
A lot of these latest problem with the spreadsheet is because the spreadsheet was developed not expecting any regional to have more than 97 teams. Since we have 100 teams in each division, there was not enough room to put the standing data between 1 and 100. There are also more matches than I have allocated room for. I have to add rows and there were a lot of changes in the macros and formulas that I sometimes missed.
After the championship is over, I will need to clean this up and probably delete and redo all the links once and for all.
  #180   Spotlight this post!
Unread 18-03-2013, 00:12
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
wow. that is truly an amazing work of excel. Thanks for posting this, cant even begin to imagine how it was made!
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
paper: 2007 Championship Event Scouting Database, presented by Team 1114 Karthik Extra Discussion 18 10-04-2007 17:02
paper: Waterloo Regional Scouting Database astephen68 Extra Discussion 3 04-03-2007 19:34
paper: Scoring for scouting database wheeler Extra Discussion 1 27-01-2007 15:56
paper: 2006 Excel Scouting database Greg Needel Scouting 11 20-04-2006 21:41
White Paper Discuss: Scouting database Marjory Frosty Extra Discussion 0 08-01-2006 19:03
