Go to Post wood is the original carbon fibre! - dtengineering [more]
Unread 19-03-2013, 13:02
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Re: pic: How we deal with a part shortage.
Originally Posted by lemiant View Post
Thanks for the kind words. While these were made to be a replacement for the gates belt the model is not actually there. I got the tooth pattern from the SDP-SI CADs and made the rest. That might just mean we're messing with someone else's copyright but I'll look into it.
You could also probably CNC it out of a block of alum. The 5 mm profiles for GT2/HTD is big enough to let you get a 3/32nd endmill in between the teeth. We machined all of our own pulleys and so far they have been working great in drive.
