Go to Post We have donut eating contests to see who has the best legs. We paint our pigs. We argue about which time zone we are in. About 400,000 of us gather together to watch cars go around in a circle. We also build robots.Yep, our cultural norm is a bit different. - Andy Baker [more]
Unread 22-03-2013, 11:24
savage's Avatar
savage savage is offline
FireFighter Paramedic
AKA: Ben White
FRC #1368
savage will become famous soon enough
Send a message via AIM to savage
Re: pic: Who should have gotten the foul? part 1
If a bot has at least one way of egress from a possible pin, like in this match that your complaint is about then there should be no pin called or blockading. As 3284 sole role in the match was to block the shooter. Now my .02 i think the GDC needs to change the max height rule for when you are on one side of the field or the other. They have done it in the past I just cant remember at this time.
And for the last time NO Instant REPLAY EVER!!!!!!!!!! Most events run late as it is, and this is why we have 5-6 REFS on the Field at one time, to cover all the zones. Yes they miss calls but so does the NFL and they have replay.
But Back to the match on hand, the Red Alliance should have seen this coming and changed their game plan. They got Tunnel Vision and missed the other two bots scoring undefended, which was a huge mistake and cost them the match.
2004 Orlando Regional Rookie Team 1368 Student
2005 Orlando Regional Student
2006 Mentor Team 1944 Hafia Israel
2006 Isralie Regional Referee
2007 Mentor Team 1368
2008 Fire Acamdey
2009 Orlando Regional Scorekeeper
2009 Orlando Regional Scorekeeper2010 Orlando Regional safety Advisor
2011 Orlando Regional Referee
2012 Orlando Regional Referee
2012 National Champs Referee
2013 Paramedic school
Unread 22-03-2013, 12:24
Zakreon Zakreon is offline
AKA: Tommy
FRC #3284 (4-H FIRST LASER Robotics)
Zakreon is an unknown quantity at this point
You're pretty well spot on there Todd. Red received a technical foul for blocking our team from returning to the autonomous zone, and we received a regular foul for moving out of the zone before our net could lower. There were also 2 separate fouls on red for contacting the blue pyramid.
1288 also had a great shooter, but it was broken in this match, they couldn't shoot. 1706 was their only viable offensive bot, it actually does make sense that both 1288 and 1444 would be trying to push us out of the way to let 1706 score.
Unread 22-03-2013, 13:08
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
I saw two touches of the pyramid, one at 1:30 and one at 1:35. I reviewed the rule for pyramid touches:
G27
ROBOTS may not contact or otherwise interfere with their opponents’ PYRAMID. Inconsequential contact will not be penalized.
For the first touch, the only robot touching the blue pyramid was the red robot, so the contact was inconsequential. For the second touch, a blue robot lined up on an opposite corner to shoot while the red robot was still touching. I ruled this as also inconsequential.
At 2:02, at first it looked like red might have touched while blue was hanging, but I could see a white disk on the ground between the red robot and the pyramid, so no touch.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 22-03-2013, 13:33
AKA: Tommy
Those may have been unwarranted, but I do believe that they received fouls for the contact.
Unread 22-03-2013, 14:57
Shane 2429 Shane 2429 is offline
FRC #2429
Shane 2429 is infamous around these partsShane 2429 is infamous around these parts
I agree that it was a bad call because you can clearly see that the defender could have dropped their net and in all reality the driver of the robot should have seen that in a 2v1 push match he was going to loose and in all reality those two robots were just trying to protect their shooter
I also seen the possible pinning call that could have been made though in all reality somebody messed up in the scouting for that match cause whoever was originally defending was way too underpowered to be trying to defend against that robot.
Also there is a point in match when you need to switch strategy cause there's was no reason why those other two robots on blue should have had free reign in their shooting ally .
Unread 22-03-2013, 15:09
AKA: Tommy
Actually we aren't able to lower the net unless we can quickly jerk the bot around, its a problem with how the brackets connecting to the net are designed. We are making new brackets for our next regional to correct this problem.
Unread 23-03-2013, 08:59
ericbanker ericbanker is offline
FRC #1208 (The Metool Brigade)
Team Role: Electrical
ericbanker is an unknown quantity at this point
1288's shooter was broken? So that's why they were forced to play defense. Does anyone know when and how that happened? 1288 had a really great robot, their shooter was a bit better than ours, and what I believe was a sideways turned holonomic/mecanum drive was really innovative.
Edit: I just rewatched the matches and they were shooting fine in the 1st finals match. They must have gotten damaged from the impacts by defenders in that match...but then they score a buzzer beater into the 3 point goal. So I'm still lost on what happened. In match 2, their autonomous fails to launch discs, and you can hear it clicking.
Unread 23-03-2013, 12:16
bulbajackel's Avatar
bulbajackel bulbajackel is offline
Programmin fo dayz
AKA: Chuck
FRC #2408 (Shrapnel Sergeants)
bulbajackel is an unknown quantity at this point
It happened somewhere where the robot just didn't respond to the field i believe. I don't know the specifics, but whatever happened there almost changed things. Didn't they start looking for a replacement?
"It's the programmer's fault"
Unread 23-03-2013, 13:06
AKA: Tommy
A teammate told me that their cam that raises the shooter broke in some way, so the shooter could not properly move into position to fire
