Go to Post It never stops. Championships will be in your head forever!!! MWHAHAHAHA!!! - vadyr [more]
Unread 24-03-2013, 22:52
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: pic: 1538 Wiring 2/4/2013
Originally Posted by Aidan S. View Post
I agree that good documentation is key, but even with that labelling is a necessity. It eliminates the risk of a mistake being made if a component has to be swapped. From experience, I can say that having labels at either end of our wires made my life a whole lot easier at competitions when I was on my team's pit crew.
Since everything is cut to length and zip-tied down near its relevant component, it's pretty hard to accidentally swap in the wrong cable. We've never had a cable fail.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 24-03-2013, 23:24
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Doesn't mean they won't. On our practice robot we had a PWM short to 12 volts and it caught fire. It killed a victor, the PWM and the sidecar. Had our PWMs not been labeled a 5 minutes swap could have taken a very long time
Edit:Moral of the story: Label everything! Especially the little cables to festos. When you have 6 festos and 2 breakouts things get real hairy real fast if they aren't labeled
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 25-03-2013, 01:51
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
I'm not a huge fan of labeling where it isn't necessary, especially in our application.
As Connor mentioned, cables are neatly ziptied and cut to length.
At the San Diego Regional, we happened to have a metal shaving short out our digital side car, meriting a complete replacement. The digital sidecar was replaced and tested in under 2 minutes. Not many teams can replace a fully loaded DSC in that time even if it were labeled.
It's just personal preference.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
