Go to Post "It's robotics season; I no longer know what sleep is." - StephLee [more]
Unread 25-03-2013, 17:00
Re: pic: High Goal Worse for the Wear
Originally Posted by MooreteP View Post
The top of the rear of the goal is probably scarred due to the angle of the shooters?
The middle is probably protected by the chains?
Then, why is the top so scarred if the impact is closer to the chain anchors.
Hmmm, IDK, maybe due to the velocity of the angled shots?
I think the top hits are all coming from low (sub-30") shooters, and the bottom hits are coming from high (nearly 60") pyramid shots or full court shots. Low shots generally enter the goal at an angle, while higher shots are more level.
There is definitely way more wear on the top because it is far easier to get a repeatable shot if the frisbee enters the goal on its way "up" the flight path rather than down.
