Go to Post This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments. - Stu Bloom [more]
  #31   Spotlight this post!
Unread 22-03-2013, 12:36
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: pic: High Score in FRC Ultimate Ascent
Originally Posted by Kristian Calhoun View Post
I'm not debating that point. I've been to events this year that only had one person counting the frisbees for each alliance for the entire weekend. In such cases, it would have been nice to have some redundancy/error checking in the final counts.
We had two volunteers on each end counting them at the Detroit District last weekend and it worked really well for us. We would tally them as they flew into the goals and take the sheets to the scoring table right after the game ended. If there were any discrepancies between the scorers, we would take the discs out of the goals and count them. It was only really an issue when discs were flying into the goals very quickly (thanks, 469...).
As far as I know, we didn't get any complaints about inaccuracies. I don't know how accurate it was when compared to the results from the sensors, but it seemed like you could tell the outcome of a match as it ended unless the point totals were within 5 or 10 points.
For the record, we had 8 or 9 field reset volunteers, and it worked out well for us. Field reset was definitely more work this time than it has been for the past few years.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
  #32   Spotlight this post!
Unread 22-03-2013, 21:49
GaryVoshol's Avatar
Cogito ergo arbitro
A person at the score table at Grand Blanc today reports that while discs counted by humans* disagree with the sensor score, in most matches it is only one disc per goal that must be adjusted up or down.
* I believe, but do not know for sure, that they are counting the discs as the goals are emptied. They do a visual count at the end of autonomous.
(since 2004)
  #33   Spotlight this post!
Unread 23-03-2013, 20:16
NXTGeek's Avatar
NXTGeek NXTGeek is offline
AKA: Malachi
NXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to behold
Wink Re: pic: High Score in FRC Ultimate Ascent
FYI, the --real-- high score as of week 4 is Waterloo's 277-81, scored in Q28 by 1114/2056/1846 beating 1241/2200/4039.
2013 -Team 3476
Champion (Fall Classic)
Champion (Battle at the Border)
Finalist (Indiana Robotics Invitational)
Newton Division CHAMPIONS (Worlds)
Wild Card as Finalist Alliance Captain (Inland Empire -> Worlds)
Innovation in Control Award (Inland Empire)
Industrial Design Award (San Diego)
Semifinalist (San Diego)
2012 -Team 3476
Champion (San Diego -> Worlds)
Excellence in Engineering Award (San Diego)
2011 -Team 1425
Engineering Inspiration Award (Portland Autodesk -> Worlds)
Finalist (Portland Autodesk)
WFFA (Tim BD, Portland Autodesk)
Finalist (Seattle Olympic)
Entrepreneurship Award (Seattle Olympic)
  #34   Spotlight this post!
Unread 24-03-2013, 11:50
Racer26 Racer26 is offline
That match had 89 foul points in the 277.
The 1114/2056/4069 alliance put up 274 in the semifinals with no fouls.
  #35   Spotlight this post!
Unread 24-03-2013, 11:58
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Actually, the highest score according to FIRST data is 243 in second quarter final match...still impressive
"A genius is just a talented person who does his homework" T. Edison
  #36   Spotlight this post!
Unread 24-03-2013, 13:30
You seem to be right, but I'm sure I remember 274 going up. Perhaps a miscounted RTS score. Weird.
  #37   Spotlight this post!
Unread 24-03-2013, 13:35
Ivan Malik's Avatar
Ivan Malik Ivan Malik is offline
Any other Anthropologists out there
Ivan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant futureIvan Malik has a brilliant future
As one of the counters at Grand Blanc I can confirm this. We not only had people counting the discs as they entered the goals, but also exiting in case of bounce outs, that way we were 100% sure. Elims saw all discs counted out at the end of a match by hand twice by two different people, Quals only if a visual count was hard to do at the end (stacked discs and what not.) Auton discs were counted both during and after auton visually. We tried to think of every angle. With 3 people counting per side, sometimes 4, if the real time was off then we knew the real score.
FRC Student: 2007-2010 ~ FLL Mentor: 2007-2009, 2012 ~ FIRST Volunteer: 2012-present
Scouting, Chairman's, Mechanical, Business, Community Outreach, anything that doesn't have wires or code, but I dabble.
  #38   Spotlight this post!
Unread 29-03-2013, 00:50
AluminumNarwhal AluminumNarwhal is offline
FRC #3128
AluminumNarwhal is an unknown quantity at this point
During Inland Empire's Practice Match 25, somehow the real-time scoring reported the final score as 42-2817. Interestingly, 2803 of those points were listed as foul points.
  #39   Spotlight this post!
Unread 29-03-2013, 01:40
xSAWxBLADEx's Avatar
xSAWxBLADEx xSAWxBLADEx is offline
DaBears til 13 turned Free Agent 14
AKA: Michael Hawley
no team (Free Agent)
Team Role: Scout
xSAWxBLADEx will become famous soon enoughxSAWxBLADEx will become famous soon enough
Send a message via MSN to xSAWxBLADEx
2006-Palmetto Regional Champions with 11 and 1251 (MORT, TIGERS, BEARS, O MY!)
2007-Pittsburgh Regional Champions with 123 and 337 / Detroit Regional Champions with 123 and 903
2009-Traverse City District Competition Champions with 85 and 2645 / Traverse City District Competition Chairman's Award / Michigan State Championship Finalists with 1918 and 904 / Championship Finalist with 217 and 68
2013-Grand Blanc District Competition Champions with 33 and 1718
  #40   Spotlight this post!
Unread 29-03-2013, 02:53
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Originally Posted by xSAWxBLADEx View Post
...The picture in the post above...
Go home live scoring system,
You're drunk
But really, the foul points? I...what? Unless some ref didn't realize that his phone was set to vibrate right on top of the foul button, how is an automated system supposed to ever add foul points?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #41   Spotlight this post!
Unread 29-03-2013, 04:05
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
You're drunk
Our bot went rogue and was getting friendly with the blue pyramid. [j/k]
  #42   Spotlight this post!
Unread 29-03-2013, 19:39
dellagd's Avatar
AKA: Griffin D
If only there were 196 less foul points, then I'd be impressed.
  #43   Spotlight this post!
Unread 29-03-2013, 20:37
my guess? the refs decided to have fun and see how many times they could push the techfoul button in a match.
  #44   Spotlight this post!
Unread 29-03-2013, 22:34
JoeWithTheSpecs's Avatar
JoeWithTheSpecs JoeWithTheSpecs is offline
Glasses User
AKA: Joe M. Bolewitz
FRC #0245 (AdamBots Team 245)
JoeWithTheSpecs is an unknown quantity at this point
Pretty certain most people have seen this practice match score already, but here it is anyways;
2803 Foul points here as well? Conspiracy I tell you.
  #45   Spotlight this post!
Unread 29-03-2013, 23:48
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
28 v 26, that's a pretty close match.
But to look at it another way, we should be impressed that these alliances were able to invoke a 20pt penalty more than once a second for 120 seconds. That's actually a rather impressive feat.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
