Go to Post "Needless to say, my Roomba will be making my toast from now on" -Colbert - artK [more]
Unread 29-03-2013, 19:12
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
pic: 80/20 double drop-in nut
Unread 29-03-2013, 19:13
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Re: pic: 80/20 double drop-in nut
They Do
http://www.mcmaster.com/#drop-in-nuts/=m3euo9
Unread 29-03-2013, 19:24
its da PAT!!!'s Avatar
its da PAT!!! its da PAT!!! is offline
AKA: Pat Miller
FRC #0829 (Digital Goats)
its da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura aboutits da PAT!!! has a spectacular aura about
Send a message via AIM to its da PAT!!!
I think he means one with two bolt holes. That link you post shows that they don't exist.
2010 Boilermaker Rockwell Automation Innovation in Control Award
2007 St. Louis Regional Champion
Unread 29-03-2013, 19:35
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
while you are designing new 8020 parts, how about some 1010 series inside corner brackets and gussets where the hole locations will provide you the ability to use something other than low profile bolts and still access whichever bolt you would like later on...
8020 saves so much money... and is so expensive...
Unread 29-03-2013, 19:46
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
We have been using "weld nuts" with 80/20 for years. You can't drop them in but they are MUCH cheaper than the drop in kind - $5.11 for a package of 25. You have to remember to just load up each length of 80/20 with a few of them before you assemble the device.
I can't get the link to paste. Go to McMaster Carr and search for "weld nut." We use the "tab base with center pilot" and they work great.
Unread 29-03-2013, 19:52
yeah, i know about weld nuts... it was the double weld nuts that inspired the double drop-in nut
My Instructables
Unread 29-03-2013, 20:14
Spen.M.P.'s Avatar
Spen.M.P. Spen.M.P. is offline
FRC #3815 (Raider Robotics)
Spen.M.P. is an unknown quantity at this point
What we would do is cut a thin part of one side of the channel out to be able to later slide in weld nuts into the frame without disassembling it.
Unread 01-04-2013, 00:15
sleepyizme's Avatar
sleepyizme sleepyizme is offline
AKA: Jason
FRC #0694 (StuyPulse)
sleepyizme is an unknown quantity at this point
Send a message via MSN to sleepyizme
These most definitely already exist as a product--my team has been using them for years.
http://www.amazon.com/80-20-Inc-Econ.../dp/B006YVZNLU
this may not be the cheapest source, but it's on Google's first page of results
Unread 01-04-2013, 04:44
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
I think the difference is the ones the OP posted are drop in, meaning you don't have to slide them in the end.
Also OP what mechanism makes the nuts drop in?
Unread 01-04-2013, 06:03
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
Their profile - drop them in sideways, and then roll them into place (they aren't quite as wide as the weld nuts, but still wide enough to span the slot). There are different models (with rubber handles, set screws, or various springs) to make insertion, as well as locating, easier.
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 01-04-2013, 18:41
gravity?
My Instructables
