Go to Post All the robots win, because we built them and they work. ;) - synth3tk [more]
Unread 01-04-2013, 14:28
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Bomb Squad Swerve Steering Code
Here is a swerve calculator (Excel spreadsheet) you can use to test your code.
It shows (both graphically and numerically) what each wheel angle and speed should be for any given vehicle-desired-motion vector [FWD,STR,RCW].
Just enter the vehicle forward/reverse command, strafe right/left command, and rotate clockwise/counterclockwise command into cells A6, A7, and A8, respectively.
