Go to Post What? Thinking is required? I certainly hope not! If so, I'm toast! - Robert Cawthon [more]
Unread 03-04-2013, 14:40
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Bomb Squad Swerve Steering Code
Originally Posted by Jefferson View Post
Ether,
When I was looking at the spreadsheet calcs, I also pulled up your derivation for the formulas here:
http://www.chiefdelphi.com/media/papers/download/3027
I noticed that you defined A-D using L/2 and W/2 in the paper while you used L/R and W/R in the spreadsheet.
Both are correct.
In the paper, A = Vx - ω*(L/2)
To convert this to +/-1 joystick commands for use in the spreadsheet, Vx=STR and ω=RCW/(R/2)
So in the spreadsheet, A = STR - RCW/(R/2)*(L/2) = STR - RCW*(L/R)
This was explained somewhat in the companion paper, albeit perhaps not in sufficient detail.
