Go to Post I think it will be very hard to find one aspect of FIRST which doesn't inspire us. - Arefin Bari [more]
Unread 07-04-2013, 13:27
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
Re: paper: Take-Back-Half Shooter Wheel Speed Control
What speed sensor are you using, and how are you decoding the signal?
What motor, and gear ratio from motor to wheel?
What language are you using?
How fast are you running your TBH algorithm?
The speed sensor, is a Banner DS18VN6LP photoeye.
The 8" pneumatic wheel is direct mounted to a CIM with Hex shaft and hub.
There is a piece of reflector tape on every other face of the hex shaft, so 3 pulses per revolution.
The TBH algorithm runs is in a 10ms timed tasked loop, with metronome timer.
The code is labview, more info from this link. http://www.chiefdelphi.com/forums/sh...d.php?t=113954
We are not using gear tooth mode on the sensor, but now we are averaging over 3 pulses, because of the change to the hex shaft.
The sooner we get behind schedule, the more time we have to catch up.
