Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 11-04-2013, 15:27
MichaelBick MichaelBick is online now
FRC #1836 (MilkenKnights)
Re: pic: Team 696 Circuit Breakers - 2013 Robot
Originally Posted by sanddrag View Post
The gusset plates were manufactured between regionals and indeed added in response to failure of the welds on the floor pickup frame, due to impact. We have a new TIG welder this year that we're still learning the settings on it. Clearly, we didn't punch enough Amps into it. I really ought to fire the guy who welded those (me ). It probably didn't help that we were welding in the freezing cold when the frame was about 30 degrees Fahrenheit.
Us smashing you into the wall didn't help either. Sorry about that and glad to see you found a good solution.
