Go to Post I give props to your programmers and programming mentors. - Sgraff_SRHS06 [more]
Unread 11-04-2013, 15:55
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: pic: 2175 Wheel v2
Originally Posted by Botwoon View Post
Could you send me a picture of the worn out hubs you're describing?
Glad to see 3D printed wheels are working for you guys, in at least some extent. I think they've got the potential to open up custom wheels for a lot of teams that may have not had that option available before.
Ill try and find the wheel at the shop tonight and upload it later. we believe the reason for the failure was because of the less then ideal shaft size causing the forces not to be distributed over a large enough area in the wheel. What size shaft do you guys use it looks like 3/4.
Also the 3/8 shaft is steel (not sure the exact alloy) and they have held up through 2 regionals plus practice in the shop, i dont expect to see any failures from them, but we have two spare drive sides that we can scavenge off of if they start to fail.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
