Go to Post They hit us, we hit them, it happens. Build your robots to take a hit and it doesn't matter. - Greg Needel [more]
Unread 12-04-2013, 12:22
Standard issue Standard issue is offline
Standard issue is an unknown quantity at this point
Re: pic: HF 10" wheel
so you welded a plate drilled for the sprocket onto the wheel hub? Are you still able to remove the bearing? What chain pitch is that, looks like #40 - Bike chain.
