Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 16-04-2013, 10:12
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Re: pic: 2175 Wheel v2
The software we use to go from STL files to the X3G files that are used by the Replicator is "ReplicatorG" with the Sail Fish modification.
http://www.makerbot.com/sailfish/install/
Sailfish firmware adds velocity profiling to the Replicator, so it prints faster and with better quality. If you have two nozzles (we do), it also adds "ditto printing", which allows printing from both nozzles simultaneously. This lets you print two parts at once, if they are smaller than the spacing between the nozzles.
The options for rafts and support structure in ReplicatorG are tricky and finicky. Unfortunately, they don't always work as advertised, and you need to experiment with the settings and part orientation to get things to work right. The software uses the last settings as the default for the next part, so in that sense, it is "automatic", but I believe the installed default was with rafts and support structure turned off.
Todd F.
Photo gallery
video channel
Triple Helix mobile
