Go to Post I am a FIRST addict. But I'm also sensible. - Rion Atkinson [more]
Unread 17-04-2013, 02:19
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: pic: About Daisy Thunder
Originally Posted by ttldomination
Would you mind providing more details about your feeding system?
- Sunny G.
From day one we wanted the feeding system to be as fast as possible with the idea being the faster you shoot discs, the more discs you can shoot, the more points you can score. Originally we were going to use some sort of pneumatic cylinder to push discs into the shooter, but we felt we could get equal or greater throughput using a roller system and we wouldn't need to add a compressor.
For the most part, the feeder is pretty straight forward. When the discs enter the magazine, gravity feeds them to the bottom and the discs stack up on top of the lower roller (the 2.75" dia. drum). When we're ready to shoot, we turn the feeder system on and the bottom disc gets kicked out from the bottom of the stack and fed into the top roller.The top roller is there to prevent the disc from sliding into the shooter when the arm is down.
A lot of teams that use home depot buckets or vertically stack discs have had problems with discs jamming. "Smart Shot" helps prevent jamming problems. When the intake system is on, the feeder actually runs at a low speed. When the first disc enters the magazine, the feeder continues to run until the IR sensor detects the disc, then the feeder turns off. By doing this, the lowest disc is in contact with the top roller and each subsequent disc in the magazine gets stacked at an angle which prevents the infamous nesting problem.
Originally Posted by 1683cadder
How do you guys turn so well without a dropped center?
The purpose of dropping the center wheel is to decrease your wheelbase (the distance between wheels that are in contact with the floor). Early on we decided to go wide so that we could make the robot's intake as wide as possible. The first drivetrain design we had the day after kick-off had 6 wheels, but we found that the length of the robot was 21.5" and the distance between the front and back wheels was something around 14". With the drop center the wheel base was about 7.5". At this point we looked at our older robots and found that the wheel base was between 12" (2012) and 14" (2011). In the end we decided that the extra wheel was totally unnecessary and that we could save ourselves a good chunk of hardware by eliminating it from the design.
Team 1538 / The Holy Cows, 2005-2016
