Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
Unread 30-01-2003, 06:05
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
uh, slight problem?
i think i see two pistons. not entirely sure, but it sure looks like two pistons. the two rods on the upper right side, i believe they're both pistons.
now, i can't tell which size pistons they are, but if you have two gearboxes, each using two pistons, wouldn't that mean you need to use the piston FIRST gave out? and having an 8 inch stroke piston isn't all that great for a gearbox...
it also means that team 60, no matter what, cannot use any other pistons at all, no?
i don't mean to be a nitpick or anything, but i would think that if indeed you flaunt the rules in using four custom pistons, that FIRST would be rather mad.
now of course, if there's only one piston, or you are indeed using the 8 inch stroke piston as one piston, then take no heed to what i said. if not, you may want to reconsider (even though it's halfway through build).
AIM --> Woloi
Email --> ian@woloschin.com
Disqualifications archiver 1999 13 23-06-2002 21:53
