Go to Post As a team leader if I do not INSPIRE I have failed, and I do not like to fail. - Mike Martus [more]
Unread 19-04-2013, 14:22
Nuttyman54's Avatar
Mentor, Tactician
AKA: Evan "Numbers" Morrison
Re: White Paper Discuss: Team 33 Four Speed Transmission
Originally Posted by fb39ca4 View Post
Anyone tried replacing the pneumatic pistons with a more powerful motor and a lead screw?
I would not recommend this. Due to the "crash" style of shifting rather than the dog-gear style used in AM supershifters and most FRC shifting transmissions, there's a high chance that the gears do not immediately engage. We noticed this when we built them in 2006. The pneumatic shifting style is well suited to this application, since it will apply a constant force, so it will continue to try to shift until the gears mesh right. A lead screw or other motor driven application has a much higher chance of breaking something, since you will either stall the shifting motor or continue to increase the force until something bends or breaks.
A NOTE TO EVERYONE:
This transmission was designed in 2004 for the drill motors that were given in the kits. These motors had a MUCH lower free speed rpm than CIM motors. 971 attempted to use CIMs with this transmission in 2006 and did not have good results. The transmission really is not designed to work at those loads and speeds, and required several extra stages of gearing before and after to bring the speeds down to what is reasonable for FRC drivetrains. It's a good transmission, but the design as-is is not really suitable for drivetrains with current FRC motors.
White Paper Discuss: Team 188 Woburn Robotics 2004 Gearbox Design Report CD47-Bot Extra Discussion 5 17-03-2009 18:45
White Paper Discuss: An Introduction to C Programming for First Robotics Applications CD47-Bot Extra Discussion 10 26-11-2004 21:54
White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission CD47-Bot Extra Discussion 4 14-07-2004 15:43
White Paper Discuss: Chief Delphi Segway Fundraiser Info CD47-Bot Extra Discussion 1 21-06-2004 09:48
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 23-01-2004 20:16
