Go to Post As a real pig farmer*, I definitely endorse team 1902. - Andy Baker [more]
Unread 20-04-2013, 13:41
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Re: pic: GoKarts! - BurnoutChibi
Well the problem with cheap chinese motors is they do explode now and then... Those brushless motors are about $40 each and 4x as power dense as a cim, each one can pull about 2000 watts.
He has other goPRO video on his other carts on his site, and video of this one should come once things settle down in boston.
So far the vex gearboxes seem to be doing fine, I like the cable shifter idea instead of using pneumatics. The motors he used already had an 8mm shaft, so he just milled in 2mm key way and machined an adapter plate.
Oh awesome Akash small world indeed.
