Go to Post Honestly though, having a cave would be one of the greatest places to build a robot. There's already lack of light and lots of floor space! Well, if you have a good cave sponsor, that is. - Bryce Clegg [more]
Unread 03-05-2013, 01:07
Gagandeep Singh's Avatar
Gagandeep Singh Gagandeep Singh is offline
AKA: Gag
FRC #1241 (Theory6)
Gagandeep Singh is an unknown quantity at this point
pic: Team 1241 - 2013 Drive Gearbox
Unread 03-05-2013, 01:09
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Re: pic: Team 1241 - 2013 Drive Gearbox
I really like this packing, any chances of an CAD file?
Unread 03-05-2013, 01:39
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Just a tip for any future iterations: use the mounting holes of the CIM for standoffs. You can thread the screws going through the standoffs into the CIM and never need to worry about nuts.
-Plutarch
Unread 03-05-2013, 09:13
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Wouldn't this make it harder to change out the motor, or the gear on the motor? When you take out those screws, the whole box falls apart then
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 03-05-2013, 22:49
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Well, usually the screws in the CIMs aren't the only thing holding the gearbox together. The WCP DS uses this, and I believe it's a fairly common feature of 971 gearboxes, among other teams.
-Plutarch
Unread 03-05-2013, 23:53
kevincrispie's Avatar
FRC #0971 (Spartan Robotics)
The CIM standoffs and the CIM screws are separated in our gearboxes. We have used PEM nuts in the gearbox for some time for fastening. They get pressed into the sheetmetal and work really well for us.
In hopes of not derailing the thread original purpose completely, I'd be curious in hearing from 1241 what we some of the specific changes they made this year and how they turned out for them. Would you guys do the same thing again?
If anyone is curious about 971's design this year or previous years, I'd be happy to discuss it offline.
Unread 04-05-2013, 13:37
AKA: Gag
FRC #1241 (Theory6)
The main change from the standard AM shifter is that the sprocket placement is now on the outside of the gearbox, which allowed us to change or drive ratio easily if we found our calculations to be incorrect or not ideal. This also allowed for quick one time assembly of the gearbox.
The concept worked very well for us this year as we did find the need to change ratios early on in competition, however we might switch the final ratio to gears.
Another change I know we will definitely do for the future is swap to aluminium gears. we happened to buy 2 full set of steel gears right before vex pro launched there new product line.
We also have used PEM nuts in the past but have found them to be more of a hassle than locknuts.
