Go to Post The spirit of FIRST is about learning not just about winning. - MamaSpoldi [more]
Unread 23-05-2013, 20:09
pranav1014 pranav1014 is offline
FRC #1127
pranav1014 is an unknown quantity at this point
pic: Swerve Shifter
Unread 23-05-2013, 20:10
Andrew Remmers's Avatar
AKA: Andrew Remmers
Re: pic: Swerve Shifter
This looks like a good start! I didn't even think about shrinking my Swerve design by adding the ballshifter!
Exploding Bacon 2007-2011
Unread 23-05-2013, 20:28
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Is that drive chain exact c-c? If it isn't, you're going to need to look into tensioning...
-Plutarch
Unread 23-05-2013, 21:10
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Or some GT2 5mm timing belt with C-C
Unread 23-05-2013, 22:52
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
the only thing that concerns me is the module itself doesn't look like it will survive missing two of four sides, butt you may have suppressed them to show the innerds. Either way looks great love the ball shifting to narrow down the gear box.
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 24-05-2013, 02:51
FRC #1678 (Citrus Circuits)
Is the whole weight of the robot supported by that one bearing? TBH that's absolutely terrifying. I would't be surprised if the jerky movements of the bot make that bearing pop right out.
How is your turning pulley mounted to the module? In this render it appears to be mounted to the drive shaft, but that can't be right.
What's holding your miter gears and sprocket in place? What keeps the gears from sliding on their shafts, and what keeps the top gear from sliding down?
How do you plan on making the turning module frame? Is a solid piece of metal or do you plan on making it in multiple parts?
Anyway, great job on getting the whole shifting gearset to be single stage!
-Adrian
Unread 24-05-2013, 06:18
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Looks pretty darn good!
Personally, I would move the module rotation belt and stuff inside the housing, rather than hanging below like it is. That will allow you to put a thrust bearing between the module and the lower plate of the housing, which is pretty essential if this is going to actually support a robot.
I'd suggest taking a look at 1640's swerve designs. Their design is very effective on the field, and they have been good enough to release basically everything you could ever want to know about it online, including CAD models.
I'm not saying "Scrap your design, go with theirs" but a lot of the challenge of swerve drive is finding the issues that you can't forsee in CAD, and fixing them. And they've already done that part for you
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 24-05-2013, 10:05
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Few comments:
-You need a sensor location for both the steering and drive. An absolute encoder is preferred for steering, team 1640 has excellent information on such sensors. It looks like you retained the US Digital drive gear from the ball shifter.
-You need a lot more support for the entire module. Specifically:
--Thrust surface on top
--Something to react module torque on the pivot - either a needle bearing on top, large bushing surface, or a delrin ring around the bottom which reacts to a chassis member.
--The drive axle should react no force except the torque it is driving
-The drive chain is fine exact c-c, you will have no problems with a chain of that length and sprockets of that size.
Kettering Motorsports
Unread 24-05-2013, 11:12
FRC #1127
As of now it is, I realize that should be changed and will find some way to do so.
There are three holes drilled into the pulley and the module. It will be bolted together so they both move.
This was one of the problems I faced originally. My best guess is super gluing the key shaft, but I really do need to find a better solution.
Sadly, I do not have the resources to make this, but if it were to be made I would either use one solid piece or make multiple parts and try welding it together.
Unread 24-05-2013, 16:43
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
I like the use of the ball shifter in this application, but I've got some questions
It looks as if your drive shaft (3/8" of 1/2") is your pivot axle and is taking all of the axial, radial and shear loads. I would expect this shaft to fail in use.
What bears the weight of the robot (the axial load)?
How is the rotating pivot cage secured to the vertical drive axle? This will be a high-load joint, but I don't see how this is done in the drawing.
A clever approach.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
