Go to Post Successful teams - in almost any aspect of life (i.e. not just robotics) - don't make excuses and assign blame when something goes wrong. They improvise. They adapt. They overcome. They correct the problem and move on. - dlavery [more]
Unread 27-05-2013, 15:13
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: paper: Relative Success of Championship Teams based on Qualification Method
Are you ready for a graph with way too many lines? The new summary has been uploaded.
I would have broken out the Alliance positions of the Regional Winners in the first place if I knew that I could at the time. I thought it'd be impossible to do as someone without any experience web scraping data, until I remembered that 1114's Scouting Databases include all alliance selection results (thanks Karthik et. al.!). Using that as a base, I cross-referenced with the All Awards Database and online FIRST data to fill in the blanks and correct for errors. I don't think it's 100% accurate, but I'm sure it's pretty close.
I also decided to break out veteran Chairman's Teams and first-time Chairman's Teams. Over time, the ratio has swung from mostly first-timers to mostly veterans, but there's enough of each to make both lines pretty smooth. It does show that the bigger Chairman's Teams (Hall of Fame and, to a lesser degree, multiple RCA winners) tend to do better robot-wise.
In 2004, Regional Chairman's Teams outperformed the Hall of Fame, but as teams like 254, 67, and 111 (among others) won CCAs, the RCA line dipped significantly and the Hall of Fame line rose. Nevertheless, as excellent as the Hall of Fame teams are, I don't think the downward trend can be wholly attributed to steady expansion of the HoF. Each year, more of the CMP qualifies competitively (Champion, wildcard, etc.), so it makes sense that the teams that qualify otherwise perform worse relative to the rest of the teams.
It's possible we'd see a different trend if we were using absolute measures of success, rather than relative measures.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 29-05-2013, 08:54
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Well the captain and 1st pick lines do make sense. Before 2008 it was rare to have 12 matches at a event and the seeding would rarely yield a true number 1. But as most know the first pick is usually the first or second best robot at each event.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 30-05-2013, 10:25
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
I ... have broken out the Alliance positions of the Regional Winners ...
Wow, that is very interesting.
I had expected that the Regional Winners Captains / 1st-picks would be high-performing, but still below the District CMP teams.
What I had not expected was that the "Regional Winner 2nd-picks" would underperform RCA, EI, and basically every other category of robot other than the Rookie All-Stars.
However, when thinking about it, if the ranking system is doing a reasonably good job of sorting robots by robot capability and the draft is doing a reasonably good job of ordering the remaining teams, then the 2nd-picks of a regional winner are likely about the 17th to 24th best robots at the regional. At a 40-team regional, these are about the middle of the pack. Thinking of that in world-wide terms: there are about 2500 teams worldwide - the middle of the pack would be robots ranked about 1200-1300 worldwide. It really shouldn't be surprising that very few of these robots appear in the elimination rounds at CMP, as the CMP eliminations would be expected to be 96 of the best robots in the world.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 20-05-2014, 03:49
Basel A's Avatar
AKA: @BaselThe2nd
Updated these numbers. New chart.
A few notes:
I only used the first 24 teams in elims from each division. I'm not deriding the role that 4th teams played on alliance, it was just to keep the number consistent from year to year. I can't pick out who the 25th through 32nd teams would have been for 2004-2013, so I chose to leave them out for 2014.
There's a downward trend in the district teams' success rate. Possible explanations include the increase in qualifying teams from Michigan, the addition of the NE and PNW district systems, regression to the mean, and random year-to-year variations. I personally think it's mostly the last one. If there's interest, I could break out the different district systems' success rates, which could shed some light.
This was a historically bad year for Rookies at the Championship. Only two made it to elims, and they were not in the top 24. It was also bad for registered teams, none of whom made elims, but that can mostly be explained by the very small number of registered teams at the CMP this year (four).
-Paul Copioli
