Go to Post Little kids playing soccer....or a typical Lunacy match. Ah, memories. :cool: - Travis Hoffman [more]
Unread 05-29-2013, 06:07 PM
Tmaxxrox97's Avatar
Tmaxxrox97 Tmaxxrox97 is offline
FRC #2512 (Duluth East Daredevils)
Tmaxxrox97 is an unknown quantity at this point
Re: pic: Team 610 - 2013 Electronics Board
Originally Posted by Mr. Lim View Post
I can't really comment about the drivetrain, other than the fact that I really like it, and that student designer Ryan Tam (Gr. 11) deserves a tons of recognition for the design and manufacture of it. He worked under the mentorship of Mr. Stehlik, and there are a lot of neat little details in it that just don't show up in this picture... (i.e. all 4 side plates are identical, how the square channels are securely connected to the side plates with only one fastener, the in-between CIM "floating" encoders + mounts)
It's not flashy, but it's really well thought out, with a ton of detail to maximize ease of machining, assembly, and maintenance.
Is there a CAD file of this drivetrain available? The floating encoders and mounts sound like a really cool idea and I would like to take a look at them if I could.
If it (the robot) is strong enough to do the task, it should be able to handle any abuse a 16 year old with a joystick can throw at it. --MrBasse
Unread 05-30-2013, 01:20 PM
jamierose jamierose is offline
FRC #4039 (MakeShift)
jamierose is just really nicejamierose is just really nicejamierose is just really nicejamierose is just really nicejamierose is just really nice
We will probably upload our CAD to www.frc-designs.com at some point in the future. I would do it now, but unfortunately, I, and many other members of our team, are currently writing exams, so we don't have much time to sort out our CAD and upload it. I'll explain a bit about how our encoders are mounted.
As you can see in the picture, our CIMs are pretty close together. We made a small plastic piece with our 3-axis CNC router that looks like a rectangle with a semi-circle cut out on either side of it. These portions of a circle are made to fit perfectly around a CIM. There was a hole in the middle of the piece for an encoder to fit through so we could screw it on. We then slid the piece in between the CIMs. The friction was enough to keep the plastic piece in place.
We then used our usual method to connect the encoder to the shaft. On 610 we use a technique we borrowed from 188, which is using surgical tubing to connect an encoder to a shaft. We simply slide the encoder into one end of the surgical tubing and the shaft into the other end. It works extremely well and we have never had issues with it.
If you have any more questions feel free to ask or message me! Hopefully we'll be able to get that CAD uploaded soon.
