Re: pic: Modular Prototype Drive
With what you have built are the wheels only connected to the gear boxes going to be powered?
We have a sprocket between the wheels to drive the other wheels so we can have six wheel drive.
Then that is a double-sided cylinder, both with spring returns?
For competition I will have to attach it different. ( Can't drill and tap cylinders - modifying a cylinder is not allowed) |
Or, you could build a custom sleeve to fit over the end of the cylinder that you can drill and tap (and then pin in place on the cylinder). |
