Go to Post IRI ... no contest. It is borderline insane. - Paul Copioli [more]
Unread 09-06-2013, 18:29
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
Re: pic: Modular Prototype Drive
Originally Posted by Wren Hensgen View Post
Then that is a double-sided cylinder, both with spring returns?
We attached a threaded rod to one end of the cylinder.
For competition I will have to attach it different. ( Can't drill and tap cylinders - modifying a cylinder is not allowed)
Unread 09-06-2013, 18:48
Mark McLeod's Avatar
Mark McLeod Mark McLeod is offline
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Mark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond reputeMark McLeod has a reputation beyond repute
Why wouldn't you use a COTS cylinder already end tapped, e.g., ?
"Rationality is our distinguishing characteristic - it's what sets us apart from the beasts." - Aristotle
Unread 09-06-2013, 19:25
EricH EricH is offline
Would it be possible to have the cylinder trip a linkage system, not unlike a 4-arm servo arm actuated on one end of one arm, that would do the shifting? That would also negate the possibility of one side shifting before the other.
Or, you could build a custom sleeve to fit over the end of the cylinder that you can drill and tap (and then pin in place on the cylinder).
