Go to Post "I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." -Woodie Flowers - Barry Bonzack [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 20-06-2013, 12:47
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Real velocity Measurement Sensor
Has anyone achieved the perfect velocity sensor platform?
I've seen measurements done with mice (x/y), but that wouldn't help too much with rotation. I believe a set of 3 or 4 sensors (three would be easier) arranged in an equilateral triangle underneath would achieve that.
Encoders? Don't catch slippage.
Accelerometers? Can be affected by jerk and/or require precise timing and encoding (see rotation).
Gyros? Fix the rotation issue- assuming the lever arms are correctly accounted for.
Ultrasonic? Some great success on a whitepaper at 40mph with a modified set of transducers.
GPS? Heh.
Wifi signal?
Suggestions would be most welcome. I've been wanting to build a sensor for this for years.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 20-06-2013, 13:51
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Real velocity Measurement Sensor
Four encoder signals (one for each wheel) run through a sufficiently complex model can estimate vehicle motion even if there is wheel slippage.
Or you can put an encoder on each of three appropriately placed unpowered omni follower wheels and use those 3 signals to compute the three independent motions of the vehicle (X,Y,rotation).
Unread 20-06-2013, 13:54
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Have you looked into a follower wheel assembly?
http://www.chiefdelphi.com/media/photos/32440
Mark
Brick walls are for other people. - Randy Pausch
Last edited by kramarczyk : 20-06-2013 at 13:55. Reason: Apparently I spent too much time reading the thread that goes with the picture.
Unread 21-06-2013, 12:18
AKA: Jason
FRC #3015
Indeed, I have.
Many of these work only if there is no slippage, or (as in the encoders) if you aren't slipping while in a pushing match (sometimes with a wall). The followers are arguably the best solution as they can sense what your real integrated displacement is, assuming they don't slip, and with care and thought you could model most of the turns and dips.
It does require contact, however, and I think back to the "Moon" competition where we were unsure if followers would be allowed. A non-contact type sensor would be ideal- which limits you to optical, sound, or ? But then that's the problem with all sensor platforms... they must keep getting more and more complex to filter for the undesirable motions.
Unread 21-06-2013, 21:15
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
I know of one team that did exactly what I think you're trying to explain using modified laser mice, sitting half an inch above the ground (no contact = no slipping). I'm still trying to figure out exactly how they did it, though. I think they probably used a coprocessor to interpret the information from the USB cables.
I've been trying to figure out how to perform the math behind this for two seasons! The idea I'm working with has four unpowered wheels, though, arranged in a square.
Unread 21-06-2013, 22:49
Ether's Avatar
Rookie Year: 1969
Originally Posted by ekapalka View Post
I've been trying to figure out how to perform the math behind this for two seasons!working with has four unpowered wheels, though, arranged in a square.
The vehicle only has 3 degrees of freedom in the plane: X, Y, and rotation.
So use 3 sensors, appropriately positioned, and the math is simple.
Unread 22-06-2013, 08:28
Gdeaver Gdeaver is offline
FRC #1640
A camera and 2d optic flow algorithms will give you x and y. A optic mouse is an example of a sensor that uses optic flow to give this. The problem with mice sensors are the optics and the maximum velocity they can work at. Recently, some drone hobbyist have taken a good camera and interfaced it to a Cortex M4 Arm microcontroller. They also added a ST Micro gyro. There is not allot of feed back as to ground based applications and I believe it is best at greater than 12" off the floor. Different optics and some Lighting experimentation may yield a very good solution. Our team has been looking at auton navigation this summer. OpenCV has optic flow algorithms that could be used if these solutions are not fast and accurate enough. Goggle optic flow and check Wikipedia. A gyro and an accelerometer like the Invensense MPU-6050 will give a very good tilt compensated Yaw.
The other possibility is to use astral navigation. Every event has lights in the ceiling that are fixed like stars. Point a camera up at the ceiling. Using some filters a pixel matrix of dark and light (0 and 1) can be produced. Then run 2 d optic flow on that matrix. The lights are far enough away that some triangulation can also be done. Every event has different lights and it would have to be calibrated at each event. This stuff is hard else every one would be doing it.
Unread 22-06-2013, 14:26
DonRotolo's Avatar
Back to humble
FRC #0832
Velocity relative to what? Whatever your answer, that (thing) needs to be part of the solution.
Even the carpet can slip if you push hard enough.
If a contact solution isn't desired, then contactless means optical of some type, or maybe ultrasonic.
Astral navigation would work, but what a pain to do. It would have to adapt to the current lighting setup no matter where. I have a "Mint" floor cleaner, it uses something like that, but the pattern is fixed. (It sends an IR pattern to the ceiling, which the Mint uses for navigation). This is still optical though...
Unread 24-06-2013, 12:03
AKA: Jason
FRC #3015
I'm dumbfounded.
I've worked with space based navigation and lever arms and planes and Kalman filters. .. and I have never, ever once considered looking up to navigate.
*bows*
