Re: pic: 6CIM WCD
Have you considered how your corner gussets will stand up with significant torsional loads? Or are you using a bellypan? Also, how will you make sure that the two sides of the drives are parallel? Rivets holes usually have enough play in them that locating of them doesn't work super well. Are rivets the only things holding the frame together, or is the tubing welded too?
I only ask because I've recently been working through some of the same design problems myself. It's interesting to see how different people have worked through the same problems. By the way, I really like those bumper extension tubing thingys that surround the center wheel. |
Re: pic: 6CIM WCD
I would much prefer welding the tubing but my team has never had success welding aluminum. We have access to a Miller Syncrowave 200 TIG and a Snap-On MIG 300, but no one with much experience welding. Would it be worth having some members learn and practice welding in the off season? |
Re: pic: 6CIM WCD
Bellypans do add a lot of strength (especially torsional, which was partially why I mentioned it to begin with). If you're designing a WCD, you've probably seen some well done bellypans before, but even just for inspiration, take a look at 254's or 1538's. They do a really great job with the elex layout. In terms of keeping the sides parallel, it will definitely help. There will be a lot of rivet holes far apart on a bellypan. Because they'll be separated by a longer distance, small amounts of wiggle in the rivet holes will change the relative angle of the two frame pieces you're joining less than it would witj your gussets right now, where the rivet holes are relatively close together. (If this made no sense, consider the effect of changing the length of one leg of a right triangle a with either a small or large hypotenuse. With a longer hypotenuse, changes in the leg will have less effect on the opposite angle.) Welding is both a lot of fun and very useful in FRC. I highly suggest that people learn it, especially TIG, during the summer. I've recently taken up TIG myself, and can personally attest to how much results are driven by experience and practice. TIG is generally considered to be better for thin aluminuim (like in a frame for FRC), but if MIG's more your cup of tea, do that, it works fine too. I don't know about your machines in specific, but Miller tends to make nice equipment. I've changed my mind several times on this, but my current thoughts on welding vs riveting are these: do both. Welding is very strong, but tends to warp frames (and a lot!) if it isn't done with proper care. Even careful tack welding, shimming, and fixturing can leave you with a slightly warped frame. Riveting, on the other hand, is much faster, and of course is less permanent. However, as I touched upon earlier, it isn't quite as strong. My advice at this point is to make your gussets be fixtures for welding. Set up the frame nice and square, rivet it all together, and see how it looks and performs. Then, clamp it to a welding table, and, tack welding first, etc. etc, weld it together. You ideally get the strength of welding with the ease and straightness of a good riveted frame. As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. |
Re: pic: 6CIM WCD
Adding a plate that links the gearboxes together is great for additional strength.
Re: pic: 6CIM WCD
We used overly thick 1/8" gussets and a 1/16" solid belly pan this year instead of welding. Chassis was just as rigid, really. No noticeable performance or strength difference at all. Welding is not mandatory for this kind of drive. And there is definitely no need to do *both* permanently. ![]() Here's a picture of our setup. The thickness of the gusset and the number of rivets used were both excessive, but rivets are almost "free" in terms of weight. Last edited by Chris is me : 07-07-2013 at 11:07. |
Re: pic: 6CIM WCD
What hasn't been mentioned yet is that belly pans are almost critical for resisting shear -- never mind torsion. My bosses at work call shear the forgotten force, and for good reason; it's more difficult to simulate than simple point/line loads or torsional loads. Something as thin as .025" sheet aluminum, even with additional lightening holes, will make your whole frame much stiffer when it experiences shear forces.
Re: pic: 6CIM WCD
Re: pic: 6CIM WCD
Our 2011 and 2012 robots were entirely riveted, no welding of the frames. Our 2011 WCD was not noticably different from the others in terms of strength or rigidity.
I hate anecdotes, but I'll be a hypocrite; Rivets hold airplanes together. Also, the bellypan doesn't have to be exotic like 233/254 does. We made two of those and while they are cool, the resource cost is so high. We've run both garolite (G-10/FR4) and a high quality 6mm plywood with great results. Last edited by AdamHeard : 07-07-2013 at 16:21. |
Re: pic: 6CIM WCD
Rivets are rigid enough to hold drivetrains together, no problem, just as you said. We riveted (and didn't weld) parts of our drivetrain together this year and the year before. After the rivets were installed, the drive was quite rigid. However, I definitely noticed a significant amount of play before the rivets were installed. I do wish I had taken more care to make sure the drive was square, as rivets aren't perfect for locating frame members together. A bellypan certainly would have helped with getting everything square before the rivets were installed. Riveting with a bellypan is probably perfectly square, strong and rigid. But, if the OP has TIG and MIG welders in house, why not learn to use them in the offseason? Just like I said before, it's perfectly fine to completely disregard my (or anyone else's) advice on CD. Personal experience and experimenting in the offseason should always trump what someone says on this forum. |
#10
Re: pic: 6CIM WCD
Not saying either method is a better fit universally for all teams, just adding more data to the discussion. |
#11
Re: pic: 6CIM WCD
They're known as "hole-grip clamps" on McMaster-Carr McMaster-Carr P/N: Tool- 5099A27 Cleco (3/16)- 5099A33 |
#12
Re: pic: 6CIM WCD
http://www.aircraftspruce.com/catalo...heetholder.php |
#13
Re: pic: 6CIM WCD
I agree, personal experience does trump the forum, I do just want to expand on what Chris said a little bit. When we rivet our chassis together all of the parts including our rivet holes are machined on our HAAS Mill. We use a #11 drill (.191) for a slightly tighter fit. We rivet the gusset plates and chassis rails together. We then use clamps and a tape measure and compare the length from corner to corner in a X pattern and adjust the clamps as necessary to square the chassis (similar to woodworking). At that point we attach the belly pan (which is not pre-drilled.) When using rivets for structural members use High Strength Blind Rivets such as McMaster part number 98778A501 they have a much high shear strength than standard rivets. |
#14
Re: pic: 6CIM WCD
