Re: pic: 6CIM WCD
However, if you're aligned perfectly the smallest of sprockets won't give you an issue. But are you really going to be perfect? |
Re: pic: 6CIM WCD
For comparison sake;
We traditionally have run 22T sprockets for 3.5-4.5" wheels, and have a lot of runtime on that. It's bulletproof. We ran 16T sprockets for 4.3" wheels for the start of the season, was bulletproof. We then ran 16T sprockets w/ 6.3" wheels, and threw the same chain 3 times. I assume some sort of minor misalignment existed that was exaggerated by the very high chain load. This was late in the season and only on the comp bot (practice was fine with massively more runtime) so we never investigated the issue. I'd say 16T sprockets are fine if your chains are all lined up properly for even 6" wheels, and are bulletproof for 4" wheels. I know this exceeds the rated working load of the chain depending on how you look at it, but whether or not that situation actually arises is unknown. |
Re: pic: 6CIM WCD
Re: pic: 6CIM WCD
-RC |
Re: pic: 6CIM WCD
Yup.
Our ground clearance was awkwardly too high to keep them out, and too low to drive over them. Looking at skirts, etc... The easiest solution was to go to larger wheels. |
Re: pic: 6CIM WCD
Funny. We went to larger wheels for fear of not being able to make it over the "bump" with our original 3" wheels. At that point, a standard zip honestly would not fit under our robot. Oops.
Re: pic: 6CIM WCD
Wow, 3" wheels? I know 254 has run 3.5"ers, but 3" is really really small! Were they that small to allow for less reduction, for compactness, or something else?
Re: pic: 6CIM WCD
3" wheels aren't really that small. I've gotten some decent clearance from 3" colsons on some CAD models on WCDs and other drive variations. If it weren't for colsons being the only source of 3" wheels, I'm sure we'd see a lot more of them in competition.
Re: pic: 6CIM WCD
In 2012 we ran a single row of rivets on the underside of the chassis siderail. When we were welding the chassis we noticed that there were a couple of areas where the siderail was not standing vertical and the top had pulled in slightly. This year, instead of running a single row of rivets, we put the rivets in a 'zig-zag' pattern and the issue went away.
Normally we run 22T sprockets so that the chain clears the chassis cross member. With this year's chassis not needing a cross member we went with 16T sprockets and had no trouble with them all year. Tensioning is huge with 25 chain, even more so IMO than alignment. In the 8 years we've used 25 chain, the only time we've had an issue with throwing chains was when the chain was not properly tensioned. |
#10
Re: pic: 6CIM WCD
Basically - there's a reason they aren't a super viable product. The teams that can handle and wish to use sub 4 inch wheels on their robots are the teams already making their own wheels. I wouldn't assume they'll work in the general FRC case just because it looks nice in CAD. |
#11
Re: pic: 6CIM WCD
Re: pic: 6CIM WCD
Sufficient to what standard?
#13
Re: pic: 6CIM WCD
1" of ground clearance is sufficient for most flat games.
