Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Unread 07-07-2013, 20:12
Re: pic: 6CIM WCD
For comparison sake;
We traditionally have run 22T sprockets for 3.5-4.5" wheels, and have a lot of runtime on that. It's bulletproof.
We ran 16T sprockets for 4.3" wheels for the start of the season, was bulletproof.
We then ran 16T sprockets w/ 6.3" wheels, and threw the same chain 3 times. I assume some sort of minor misalignment existed that was exaggerated by the very high chain load. This was late in the season and only on the comp bot (practice was fine with massively more runtime) so we never investigated the issue.
I'd say 16T sprockets are fine if your chains are all lined up properly for even 6" wheels, and are bulletproof for 4" wheels.
I know this exceeds the rated working load of the chain depending on how you look at it, but whether or not that situation actually arises is unknown.
Unread 08-07-2013, 00:11
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: pic: 6CIM WCD
Slightly off topic, but what were your reasons for switching to larger wheels in the middle of the season?
Unread 08-07-2013, 00:41
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: 6CIM WCD
They wanted to be able to drive over frisbees!
-RC
R.C.
MadTown Robotics Team 1323
Unread 08-07-2013, 01:05
Re: pic: 6CIM WCD
-RC
Yup.
Our ground clearance was awkwardly too high to keep them out, and too low to drive over them.
Looking at skirts, etc... The easiest solution was to go to larger wheels.
Unread 08-07-2013, 01:16
Re: pic: 6CIM WCD
Yup.
Funny. We went to larger wheels for fear of not being able to make it over the "bump" with our original 3" wheels. At that point, a standard zip honestly would not fit under our robot. Oops.
Unread 08-07-2013, 01:35
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: 6CIM WCD
Wow, 3" wheels? I know 254 has run 3.5"ers, but 3" is really really small! Were they that small to allow for less reduction, for compactness, or something else?
-Plutarch
Unread 08-07-2013, 03:36
Andrew Lawrence
Re: pic: 6CIM WCD
3" wheels aren't really that small. I've gotten some decent clearance from 3" colsons on some CAD models on WCDs and other drive variations. If it weren't for colsons being the only source of 3" wheels, I'm sure we'd see a lot more of them in competition.
Unread 08-07-2013, 11:59
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: pic: 6CIM WCD
In 2012 we ran a single row of rivets on the underside of the chassis siderail. When we were welding the chassis we noticed that there were a couple of areas where the siderail was not standing vertical and the top had pulled in slightly. This year, instead of running a single row of rivets, we put the rivets in a 'zig-zag' pattern and the issue went away.
Normally we run 22T sprockets so that the chain clears the chassis cross member. With this year's chassis not needing a cross member we went with 16T sprockets and had no trouble with them all year. Tensioning is huge with 25 chain, even more so IMO than alignment. In the 8 years we've used 25 chain, the only time we've had an issue with throwing chains was when the chain was not properly tensioned.
Team 1538 / The Holy Cows, 2005-2016
Unread 08-07-2013, 13:18
Re: pic: 6CIM WCD
I would call 3" wheels "really that small". On a 2x1 frame, that leaves you with a large span to high center on, as well as at most .625 inches of ground clearance right at the center wheel. We've run 4" wheels on 3" tube in 2011 and while it did clear the bumps in the field, anything other than almost perfectly flat would not have worked for that drive.
Basically - there's a reason they aren't a super viable product. The teams that can handle and wish to use sub 4 inch wheels on their robots are the teams already making their own wheels. I wouldn't assume they'll work in the general FRC case just because it looks nice in CAD.
Unread 08-07-2013, 13:42
Andrew Lawrence
Re: pic: 6CIM WCD
In my models every wheel was moved down around 1/2" on the 2x2 to provide enough clearance, and it was sufficient.
Unread 08-07-2013, 16:22
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: pic: 6CIM WCD
Sufficient to what standard?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 08-07-2013, 16:43
Andrew Lawrence
Re: pic: 6CIM WCD
1" of ground clearance is sufficient for most flat games.
Unread 08-07-2013, 16:55
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: pic: 6CIM WCD
Andrew, If you are using 2" tall tube with 1/8th" of wall and live axles in a WCD setup, then you don't have an extra half inch to drop the wheels.
The height of the tube that is actually usable in this case is 1.75" because you do not want to machine away the top or bottom walls of the tube for the bearing to fit. Then if you are using 1/2" hex like this design calls for, the bearings would be 1.125" diameter. This means that the lowest you can drop down the bearings from center without taking away top or bottom wall material is 0.3125". Assuming you already had a 0.125" drop center to begin with, this means that you would only actually be dropping the bearings (and therefore the shafts) by 0.1875". That means you have 0.6875" ground clearance with 3" wheels, not 1".
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
