Re: pic: 6CIM WCD
Re: pic: 6CIM WCD
-RC |
Re: pic: 6CIM WCD
Yup.
Our ground clearance was awkwardly too high to keep them out, and too low to drive over them. Looking at skirts, etc... The easiest solution was to go to larger wheels. |
Re: pic: 6CIM WCD
Funny. We went to larger wheels for fear of not being able to make it over the "bump" with our original 3" wheels. At that point, a standard zip honestly would not fit under our robot. Oops.
Re: pic: 6CIM WCD
Wow, 3" wheels? I know 254 has run 3.5"ers, but 3" is really really small! Were they that small to allow for less reduction, for compactness, or something else?
Re: pic: 6CIM WCD
3" wheels aren't really that small. I've gotten some decent clearance from 3" colsons on some CAD models on WCDs and other drive variations. If it weren't for colsons being the only source of 3" wheels, I'm sure we'd see a lot more of them in competition.
Re: pic: 6CIM WCD
In 2012 we ran a single row of rivets on the underside of the chassis siderail. When we were welding the chassis we noticed that there were a couple of areas where the siderail was not standing vertical and the top had pulled in slightly. This year, instead of running a single row of rivets, we put the rivets in a 'zig-zag' pattern and the issue went away.
Normally we run 22T sprockets so that the chain clears the chassis cross member. With this year's chassis not needing a cross member we went with 16T sprockets and had no trouble with them all year. Tensioning is huge with 25 chain, even more so IMO than alignment. In the 8 years we've used 25 chain, the only time we've had an issue with throwing chains was when the chain was not properly tensioned. |
Re: pic: 6CIM WCD
Basically - there's a reason they aren't a super viable product. The teams that can handle and wish to use sub 4 inch wheels on their robots are the teams already making their own wheels. I wouldn't assume they'll work in the general FRC case just because it looks nice in CAD. |
Re: pic: 6CIM WCD
Re: pic: 6CIM WCD
Sufficient to what standard?
#11
Re: pic: 6CIM WCD
1" of ground clearance is sufficient for most flat games.
#12
Re: pic: 6CIM WCD
The height of the tube that is actually usable in this case is 1.75" because you do not want to machine away the top or bottom walls of the tube for the bearing to fit. Then if you are using 1/2" hex like this design calls for, the bearings would be 1.125" diameter. This means that the lowest you can drop down the bearings from center without taking away top or bottom wall material is 0.3125". Assuming you already had a 0.125" drop center to begin with, this means that you would only actually be dropping the bearings (and therefore the shafts) by 0.1875". That means you have 0.6875" ground clearance with 3" wheels, not 1". |
#13
Re: pic: 6CIM WCD
Maybe he's using steel
#14
Re: pic: 6CIM WCD
