Go to Post Where's the "drill enough weight holes so we're barely under 120lbs" option? ;-) - AlecMataloni [more]
Unread 02-02-2003, 20:39
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
Image Discuss: 294 teaser, what's odd?
Unread 02-02-2003, 20:42
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Hmm...
Looks good. "What's odd?" Hmm...not sure...other than it looks like it wont be used to power your drive base (unless it's for some type of crab wheel moving). The 2 sprockets look like they will be driving a chain going out opposite directions of the gearbox. We thought of doing the same thing early in the build period, but instead of making the gearbox we were going to purchase some through a company.
Looks good.
/me goes back to typing his chemistry formal lab report
Purdue Alumni
Cummins, Inc.
Unread 02-02-2003, 21:34
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
Is heavy, really heavy...answer to the odd question.
Unread 03-02-2003, 00:06
C'mon it's easy. In the bottom left side of the gear/sprocket box there is a bore for a bearing but there isn't one and that shaft doesn't go all the way across.
Image Discuss: 294 teaser, what's that? CD47-Bot Robot Showcase 4 20-02-2003 00:09
Image Discuss: 294 Teaser, it turns? CD47-Bot Robot Showcase 3 03-02-2003 16:56
Image Discuss: 294 teaser CD47-Bot Extra Discussion 4 01-02-2003 21:33
Image Discuss: 294 Teaser CD47-Bot Extra Discussion 1 26-01-2003 23:56
