Re: pic: 6CIM WCD
Basically - there's a reason they aren't a super viable product. The teams that can handle and wish to use sub 4 inch wheels on their robots are the teams already making their own wheels. I wouldn't assume they'll work in the general FRC case just because it looks nice in CAD. |
Re: pic: 6CIM WCD
Re: pic: 6CIM WCD
Sufficient to what standard?
Re: pic: 6CIM WCD
1" of ground clearance is sufficient for most flat games.
Re: pic: 6CIM WCD
The height of the tube that is actually usable in this case is 1.75" because you do not want to machine away the top or bottom walls of the tube for the bearing to fit. Then if you are using 1/2" hex like this design calls for, the bearings would be 1.125" diameter. This means that the lowest you can drop down the bearings from center without taking away top or bottom wall material is 0.3125". Assuming you already had a 0.125" drop center to begin with, this means that you would only actually be dropping the bearings (and therefore the shafts) by 0.1875". That means you have 0.6875" ground clearance with 3" wheels, not 1". |
Re: pic: 6CIM WCD
Maybe he's using steel
Re: pic: 6CIM WCD
Re: pic: 6CIM WCD
