Go to Post My brain is about as full as the ChiefDelphi servers have been lately with all the info from the past few days jammed in there. - Elgin Clock [more]
Unread 08-07-2013, 13:42
Andrew Lawrence
Re: pic: 6CIM WCD
I would call 3" wheels "really that small". On a 2x1 frame, that leaves you with a large span to high center on, as well as at most .625 inches of ground clearance right at the center wheel. We've run 4" wheels on 3" tube in 2011 and while it did clear the bumps in the field, anything other than almost perfectly flat would not have worked for that drive.
Basically - there's a reason they aren't a super viable product. The teams that can handle and wish to use sub 4 inch wheels on their robots are the teams already making their own wheels. I wouldn't assume they'll work in the general FRC case just because it looks nice in CAD.
In my models every wheel was moved down around 1/2" on the 2x2 to provide enough clearance, and it was sufficient.
