Go to Post the bang for the buck is unparalled. Where else can $6000 change an entire group of student's lives forever? - Cory [more]
Unread 08-07-2013, 14:03
cadandcookies's Avatar
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
Re: pic: Team 2220 Blue Twilight Octocanum Offseason Project
One comment I would make is with the sprockets chaining the traction wheel and mecanum together, did you pick the wheel separation distance to ensure an even number of chain links? It is a bit harder to put the modules together under tension, but never worrying about throwing a belt or chain is great.
Yes! We saw the multitude of posts on that subject and ensured that we were spacing the sprockets at a multiplier of the pitch for #25 chain (.25").
If you have decided, can you tell us why you decided on the placement of the traction wheels on the inside or outside. I think there are a few obvious pros and cons to each, but would like to hear your view on it.
The current plan is to have the traction wheels on the outside. The primary reason has a lot to do with one of out mentors, who is pushing us to develop this for the 2014 season (which may or may not make sense). Our primary rationale was that, in a competition bot, one of the main benefits we wanted from octocanum was the ability to go in a very straight line without too much feedback correction (for autonomous mode). The main thing we were weighing this benefit against was being able to use a single piston on each side to actuate.
Are you using threaded rod as an axle for the traction wheel?
No, we're using 1/2-20 Grade 8 steel cap screws. We've used them on previous robots with much success-- we haven't managed to bend one in competition yet. We're still running our 2012 competition bot on the same bolts we used for our two regionals, plus championships and several demos and off-season events.
tumblr | twitter
VEXU UMN (2015-??)
Volunteer since 2011
Unread 08-07-2013, 14:33
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Fortunately the size of the pistons you need to shift is pretty small, I think ours had a stroke of 1" tops, and a bore of 1 1/16" or so, we also plumbed them all off of 1 or 2 solenoids, I can't remember what we decided on at the end of the season. You don't have to use air to pull the traction wheels back up, robot weight should be more than enough. Also, the bot was downright hard to move if it stopped in traction mode.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 08-07-2013, 15:01
AKA: Nick Aarestad
Yeah, this confirms what we were thinking about the process. I believe Aren mentioned something about "cute little 8lb springs" too.
tumblr | twitter
VEXU UMN (2015-??)
Unread 08-07-2013, 15:05
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Could you explain this further?
If you don't use air to retract the traction wheels, won't the end result be having both the mecanum wheels and traction wheels touching the ground simultaneously?
--Madison--
...down at the Ozdust!
Unread 08-07-2013, 15:59
College Mentor
AKA: Trent Borman
Was trying to figure out what the confusion was, then I realized.
We also have a small spring (maybe 1-2lbf tops) that pulls back on a small "finger" sticking up from the plate by the axle lifting the traction wheel the remainder of the way off the ground.
Here is a side profile picture with the "finger" which sticks up through a milled slot in a chassis tube.
http://www.teamneutrino.org/assets/r...drive/side.png
