Go to Post My guess is you all are planning on being overweight......interesting strategy.....i like it - Stephen Kowski [more]
Unread 10-07-2013, 12:37
Sh1ine Sh1ine is offline
FRC #2791
Re: pic: 6CIM WCD
Originally Posted by DampRobot View Post
I was less thinking of rigidity after the rivets are installed, and more before. When a rivet is first placed in a hole (but not installed) the two pieces being joined together can still move in respect to each other a small amount. 3/16" nominal rivets are designed to go into #10 (.194") holes. While the OD of the rivet is probably larger than .1875" exactly, there is still some play between the rivet and the hole when it hasn't been crushed yet.
Rivets are rigid enough to hold drivetrains together, no problem, just as you said. We riveted (and didn't weld) parts of our drivetrain together this year and the year before. After the rivets were installed, the drive was quite rigid. However, I definitely noticed a significant amount of play before the rivets were installed. I do wish I had taken more care to make sure the drive was square, as rivets aren't perfect for locating frame members together. A bellypan certainly would have helped with getting everything square before the rivets were installed.
Riveting with a bellypan is probably perfectly square, strong and rigid. But, if the OP has TIG and MIG welders in house, why not learn to use them in the offseason?
Just like I said before, it's perfectly fine to completely disregard my (or anyone else's) advice on CD. Personal experience and experimenting in the offseason should always trump what someone says on this forum.
I agree, personal experience does trump the forum, I do just want to expand on what Chris said a little bit. When we rivet our chassis together all of the parts including our rivet holes are machined on our HAAS Mill. We use a #11 drill (.191) for a slightly tighter fit. We rivet the gusset plates and chassis rails together. We then use clamps and a tape measure and compare the length from corner to corner in a X pattern and adjust the clamps as necessary to square the chassis (similar to woodworking). At that point we attach the belly pan (which is not pre-drilled.) When using rivets for structural members use High Strength Blind Rivets such as McMaster part number 98778A501 they have a much high shear strength than standard rivets.
Unread 10-07-2013, 15:45
Re: pic: 6CIM WCD
We used to use the high strength rivets, but switched to regular a few years ago. The high strength isn't worth the extra $$$.
