Go to Post The point of outreach isn't to "win" a "game" so I'm not sure what you hope to achieve with such a concept. The idea of "beating" another team in terms of outreach is fundamentally flawed. - dcarr [more]
Unread 22-07-2013, 13:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: 20's IRI Carnage
Originally Posted by apalrd View Post
I still believe the cause of failure is improper material selection or component design more than anything else, not improper use of the gearbox (it should be able to handle this). 7075 is a significantly weaker material, and without changes to the dog design (e.g. increasing thickness, additional hardening, etc.) the overall strength is significantly lower vs stainless steel.
7075 is not the problem. We have used it or 7068 since 2007 with zero failures.
Most common grades of stainless are actually substantially weaker than 7075, unless AM is using a prehard grade (13-8, 15-5, 17-4) or 410/416
2001-2004: Team 100
2006-Present: Team 254
