Re: paper: FRC #33 The Killer Bees 2013 Software - BuzzXVIII (Buzz18)
LVSC file are LabVIEW Statecharts.
The module is not included in the FRC release of LabVIEW. We arranged this with NI in return for feedback on it's use. Since I didn't expect anyone to have Statchart, I generated documentation for all Statecharts using the internal documentation tool. Every statechart has a folder called <name>_files which contains a PNG image of the following: -The statechart itself (Main Diagram0.png) -The Inputs and Outputs clusters (Inputs0.png and Outputs0.png) - I didn't use the StateData but there is a cluster for that too -The outer appearance of each block (I tried to name them reasonably, that should be in these images - #.png) -The entry/exit action of the block (for states - entryaction#.png and exitaction#.png -The guard action of the block (for transitions - guard#.png) Statechart was a great tool to work with once we learned all the quirks (e.g. when you copy-paste a block, they share the same diagram and modifying one modifies the other). It definitely helped some of the more complex state-machines we had (the first and second revision gun feeder system was very complicated). It was also helpful when debugging - I could tell the mechanical and integration people working on that system exactly what it was trying to do and how it should react. I also made some VI's to graph the input/output data which was very helpful in analyzing the strange behavior (if I do this and this and this, it jams with gate A open and gate B closed but the gun isn't on...)... But even with the automation there were still corner cases that weren't handled perfectly. But the bucket (and really simple code) had virtually none of them. |
