Go to Post The key is to get the WHOLE TEAM to understand that you are designing and building a robot, which is a complete system - not just a collection of mechanical assemblies stuck together. - SteveGarward [more]
Unread 01-08-2013, 13:43
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
Re: pic: Introducing BarBox: My First Attempt at Gearbox Design
Originally Posted by Adrian Clark View Post
Like Adam said, using an off the shelf shaft is a great idea. But I would recommend using a .375 ID 1.125 OD bearing from andymark so you can make the plates identical.
I haven't thought of that... Thanks for the tip. I'll try and incorporate this in the design.
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
