Go to Post Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience. - AustinSchuh [more]
Unread 15-08-2013, 19:01
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Re: paper: py4frc - Intuitive Desktop App for OPR, Standings, and Teamlists
Originally Posted by Ed Law View Post
Basel,
Did you check your sub-OPR numbers with my new ones? Do they all match?
That's actually exactly what I checked with. I checked a couple events and they were the same. The bug I had to fix was a team list sort problem; the shift was implemented correctly but was shifting the wrong sub-oprs to the right total oprs.
Palardy, thanks. That's probably the issue then. I'll have to see if I can condense the file somehow (or find a less sketchy depository than I'm currently using).
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 26-02-2014, 22:59
Basel A's Avatar
AKA: @BaselThe2nd
This has been updated for 2014 and will work live. Here's the file: http://goo.gl/89CZmp (warning: it's a 20 MB exe, it's not a virus). Calculates 4 OPRs: Auton, Assist, T&C, Foul. While total OPR probably won't be very effective, I expect Auton and T&C OPRs will be meaningful. It's difficult to test effectively, but I think I've worked out all the bugs. Let me know (PM, @BaselThe2nd, where ever) if you have any problems. It's still too large to upload to CD, but the link in the description will work, permanently. I'll be at home during Week 1 events to make any fixes that may be necessary.
The Python source code is available on GitHub. Feel free to use it as a module. I'm working on a larger project that takes the information available here, adds in a few nice features, and displays it all in a friendly format. Until I can release that, I'm simply making this available.
-Paul Copioli
Unread 28-02-2014, 13:07
Basel A's Avatar
AKA: @BaselThe2nd
New version (now with fewer bugs!) posted in the description. Couldn't edit the previous post.
-Paul Copioli
