Go to Post You know, I love the fact that FIRST has always got your back. :D - Beth Sweet [more]
Unread 02-09-2013, 02:04
FRC #1836 (MilkenKnights)
Re: pic: FRC488 -- Fall Project
Originally Posted by Mk.32 View Post
So if your competition frame was bent and threw chains, how does going to an all gear setup help? If you run your gear-driven frame rough and it gets bent it sounds like it will destroy gears due to incorrect mess?
The obvious solution to both is to build a frame that doesn't bend, but after that why not just stick to chain or my personal favorite timing belt? We ran our timing belt frame pretty hard this season and never had issues with throwing belts, and in the past we never threw chains (even on the kit frame) after using tensioners/careful alignment.
I agree. 971 runs timing belt which IMO requires the most precision out of the three. Chain requires the least. I think even strengthening up the frame and switching to 35 chain(which can take a lot of slop) will be a better solution that may even weigh less.
