Go to Post TIME is the one commodity you cannot buy more of. - Andy Brockway [more]
Unread 02-09-2013, 15:11
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: FRC488 -- Fall Project
I appreciate everyone's continued feedback. I am reworking the design with it in mind and will have a revision ready later on today.
Already, it's looking better, though there's obviously a long way to go.
I am pretty sure this can be assembled. I moved the assembled wheel clamshell into place from the outside in the model and, while it was a tight fit, it seemed doable.
Originally Posted by Andrew Lawrence View Post
Why not go with belts?
Ignorance, mostly. There are lots of gears and sprockets available with the "FRC bolt pattern," but not so with belt pulleys. There are the AM kit pulleys, but I don't like the ratio.
Our mill and lathe are often bottlenecks in our fabrication process, so I try to design as few parts as possible that require milling or turning. So, until belt pulleys are sold with that 6-hole pattern (and versakey! ...hint, hint), we'll not head down that path.
--Madison--
...down at the Ozdust!
