Go to Post Well, there goes our bare aluminum corner tracking full field navigation system... - Whippet [more]
Unread 04-09-2013, 01:20
Re: pic: FRC488 - Fall Project, Rev. A
Originally Posted by Chadfrom308 View Post
You are right, maybe it should be just a middle piece cut out. The reason being that this metal underbody is just added weight that can and should be removed
Done properly, the weight gains are marginal and the added strength and rigidity are quite useful. In a sheet metal drive like this, the lightened metal belly pan is what holds the entire design together (literally and figuratively).
"metal is weight and weight is bad" isn't by any means necessarily true.
