Go to Post FIRST provides evidence that many of us are optimists. - mrnoble [more]
Unread 04-09-2013, 14:37
Data Nerd
FRC #0079
Re: pic: FRC488 - Fall Project, Rev. A
I like the idea of adding a fixed data port somewhere along the outer frame. I think it'd get me a lot of brownie points with the electrical and programming teams.
As it stands now, the gearboxes are removed by lifting them upward. Since they're sealed, I'm not sure how having access to the bottom will be helpful.
Yes, that would get you brownie points.
Perhaps consider removing from the bottom since there isn't anything that can go below the chassis yet you will (likely) have a superstructure and removing the transmissions through that tends to get hairy.
