Re: paper: Drivetrain Acceleration Model
Very cool. Now if only we could convince you to use variable names longer than 2 characters
![]() Am I correct in assuming that Tm = Ts*(1-V/Vfree); on line 55 could also be used to figure out approximate current draw? Or am I over simplifying this? |
However, the model does not account for voltage drops due to heavy currents through the wires, the wire connection points, the battery' s internal resistance, changes in motor resistance due to temperature, etc so the accuracy of Tm (and the current) will be affected. Also, Kt is not strictly constant - it varies somewhat with motor temperature. Quote:
* when not slipping. when slipping, you'd have to use the kinetic friction force and back-calculate the motor torque. Last edited by Ether : 19-09-2013 at 01:48. |
Twas just a joke, I know the equations look like this but I've always found annotating them with english names helped me understand what was going on. Course, that was the second thing I did with this (first was read what heun integration was). Thanks for sharing this. |
This is cool. I wouldn't have looked up Heun's method if I hadn't seen this thing. I also wouldn't have looked up rolling resistance. This white paper has given me some homework. Hopefully I can include those two things into the calculator I've been playing with. Thanks very much for posting goodies like this.
9/24/2013 added updated C code (build 2013-09-24_2231) which includes motor voltage drops due to circuit resistance. 9/24/2013 added an explanation how the voltage drop model was derived. Last edited by Ether : 25-09-2013 at 17:56. |
Ether - Very nice, thanks for developing this. Do you think it could be extended to include wheelbase parameters and predict motor current draw when turning (say differential steering)? We've had trouble in this area during drive system design.
The executable works very well functionally-- I was able to run it with no problems and create some nice graphs based on it.
The only problem I've noticed is that I really have no idea what any of the variables are until I look back into the original program for comments. I don't think I've quite expressed my appreciation for this program enough-- it is really nice to have such a good model for generating a good estimate of how fast a given drive train setup will move. |
#10
Thank you so much for making this. You're my go-to resource for FRC physics and the community wouldn't be the same without you.
On line 84 voltage drop is calculated, but you don't ever seem to account for it when calculating the torque of the motors, is that correct? |
#11
Thanks for the words of encouragement. |
