Go to Post The programmers will kill you if you want that done on the robot!!! - cbeavers6790 [more]
Unread 23-09-2013, 16:51
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: paper: Drivetrain Acceleration Model
- added total drive motor amps to output
There's a small error in the build 9/19/2013_1112a code.
At line 75, "A*4/10" should be "A*n/10".
Unread 23-09-2013, 17:03
Data Nerd
FRC #0079
My current JS port has some minor typos that I haven't had the chance to hunt down yet. I'm working with Emscripten to compile the C code to Javascript which should mean I can integrate your changes faster too.
Unread 23-09-2013, 17:22
Ether's Avatar
Rookie Year: 1969
Originally Posted by Andrew Schreiber View Post
...should mean I can integrate your changes faster too.
That would be great.
I want to add battery voltage drop so mentors can use the model as a visual teaching tool to show students why low resistance in the motor wires and connections really does matter.
