Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Unread 27-09-2013, 09:23
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: pic: Team 359 Flow WaterJet Installation
waialua359, that fund raising is quite impressive! How does one even go about securing that level of funding?
I can't speak for 359 but you can't hold anywhere near the tolerance of a water jet with plasma.
That depends on your definition of "anywhere near" I suppose, and the particular machine being used. I see CNC Plasma vendors citing tolerances at least as low as +/- 0.004in (I assume for higher-end systems) and up to +/- 0.030in for 'entry level' systems. I believe water jets fall somewhere on the better end of that scale, generally.
Certainly low-end plasma cutters can't reach the tolerances of a waterjet, but that's comparing a $10k machine to a $100k machine.
Originally Posted by mman1506 View Post
We have a cnc plasma cam. It's really disappointing for anything other than outline cuts for welding or decorative pieces. It has a hard time making round concentric holes and requires a lot of set-up and calibration. The heat also warps the metal and heat treats it. Our CNC mill/router is much more useful for robotics purposes.
It's funny you should say that. Our CNC table requires little or no setup and calibration and doesn't warp metal when we cut it. At least it hasn't warped anything since we started using the proper current/cut rate calculators.
The the plasma arc doesn't 'heat treat' the edge of the cut, it nitride hardens it (and only 0.005-0.006in). A small distinction perhaps, but an important one. The HAZ will certainly degrade any heat-treatment in the parent material though.
We're going to use our CNC plasma table to build more and more parts this pre-season and figure out exactly how close to a finished part it can make. I imagine holes will be cut undersized and drilled to a final dimension.
