Go to Post Safety captains be watchful. - Al Skierkiewicz [more]
Unread 22-10-2013, 09:26
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Re: pic: Bumper slices
Originally Posted by IKE View Post
Has anyone found a fast dry, easy and cheap to apply numbering method? I bought a bunch of fabric paint pens, but frankly, they do not work very well. While they do meet the "legal" interpretation of white outlined numbers, they are usually quite faint and barely legible.
Does anyone else have an inexpensive and fast method for bumper numbers?
We used the iron-on numbers from the sample in the KOP last year. They were quick, easy, and looked really good. After 2 District Events, 1 District Championship, and 2 off-season events, none of the numbers have failed fully ... although a few edges have pulled up.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 22-10-2013, 12:37
mom-bot's Avatar
mom-bot mom-bot is offline
Engineers run on cookies
AKA: Ms. Reis
FRC #0175 (Buzz Robotics)
Team Role: Marketing
mom-bot is an unknown quantity at this point
Graphics staying on dry method:
This is not quite as fast, BUT they stay on and look great
Utilize or draft a NEMO that has sewing experience, a mentor's spouse or a student with sewing experience. It is even better if they understand basic upholstery construction such as used on furniture. If they are not comfortable sewing the first time on the actual bumper material initally, have them use a piece of inexpensive cotton blend for a mock up to use the cotton as the pattern for the "good stuff."
The iron on's are great, but if they can do a simple zig-zag stitch around the outside of the iron on they never come off. We typically sew ours on - sometimes the day of bagging - but they always turn out.
We have done this since bumpers were instituted and have had no issues with the graphics or the material.
The attachment to the frame is a different story. Due to the configuration of the 'bot changing from year to year it is difficult to have a consistent method for application. The best way I have seen in my six years with the team is we had bolts through the frame, head down and the bolt length sticking up. We then used a drilled bracket attached to the bumper plywood side. The bumper dropped down over the frame mounted bolts and wing nuts were used secure the bumpers. I will see if I can find a photo or a sketch and post it later. It was by far the best we have had so far.
Unread 22-10-2013, 13:49
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Originally Posted by Nate Laverdure View Post
I considered sinking a T-nut into the plywood per the manual's recommendation. I dropped this idea because (1) I haven't actually seen anybody use this attachment method effectively
We have! For year's we've been sinking T-nuts into the plywood in order to attach some C-channel that fits around the KoP chassis. Yeah, the attachment part is mostly the C-channel, but the T-nuts are pretty integral in the process.
2016: Lake Superior WFFA
