Go to Post You know you are a true tech geek when you end up on top of the Sears tower, and the only pictures you post are the ones of the radio antennae. ;) - Tom Line [more]
Unread 29-10-2013, 17:15
mman1506's Avatar
mman1506 mman1506 is online now
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
pic: Found these on our quadrennium robot checkup
Unread 29-10-2013, 17:16
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
Re: pic: Found these on our quadrennium robot checkup
Marcus, wahappen!
No lube?
Unread 29-10-2013, 17:21
AndreaV AndreaV is offline
That girl with chips in her hair.
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Those toughbox nano's are from 2011, and the mecanum robot they are in is the school's favorite demo bot. It gets a lot of use, they probably needed more lube at some point.
RIP little pinions..
Unread 29-10-2013, 18:46
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
Hmm... that's the exact situation as our mecanum robot... but we've never checked the gearboxes
Unread 29-10-2013, 18:53
MrForbes MrForbes is offline
Grease...regular maintenance....make it a way of life.
Unread 29-10-2013, 19:13
mman1506's Avatar
no team (WARP7)
Oh, I thought it was older than that. They were fairly well lubed after we rewired the robot last year but a lot of grit had collected in the open gear boxes. I'm going to chalk it up to all those joystick mashing grade 8's.
2016: FRC 865 Mentor
Unread 29-10-2013, 20:29
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Once we assemble (and grease) a TB nano, we just run a strip of duct tape around the whole thing 2-3 times. "seals" the ends and keeps stuff out. Of course, it may be harder to remember to grease the boxes, as you can't visually check them easily
Unread 30-10-2013, 07:23
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
I believe the AndyMark nanotubes were first available for the 2011 season.
Hi!
Unread 30-10-2013, 08:05
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
We first used Nano's in Breakaway 2010
Unread 30-10-2013, 20:56
donkehote's Avatar
AKA: Kevin
FRC #5031
Might be a good idea to put a grease fitting in the case if you guys want to keep using them long term. Just for the sake of maintenance.
Unread 30-10-2013, 21:19
DampRobot's Avatar
Physics Major
AKA: Roger Romani
We saw a similar problem in a WCP 11T pinion this offseason. It turned out that in our gearbox, the CIM itself was flexing around because we removed one of the spacers that held it in place. The flex created enough separation in the gears for the teeth to occasionally slip past each other, wearing the teeth over time. We replaced it with a new 11T and put the spacer back in, and never had problems again.
So, if you see tooth wear like this, it isn't necessarily a grease problem.
-Plutarch
Unread 30-10-2013, 21:25
Gregor's Avatar
Gregor Gregor is online now
#StickToTheStratisQuo
AKA: Gregor Browning
1/16"-1/32" Lexan with velcro works well here. Weighs practically nothing and you can still visually inspect the gearboxes.
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 30-10-2013, 21:37
mman1506's Avatar
no team (WARP7)
I think running the mecanum wheels on hard floors put a lot of vibration into the shaft and did the same thing. We are using white lithium grease now which is easier to visually inspect. We might 3D print or CNC some end caps that look good.
